Hi guys i am currently looking at putting a pod in my car for better airflow but i really dont want to be defected for it. Does anyone know if putting a pod in makes much of a diffrence or is it just better to put a better filter in the standard airbox? Another option i thort of is putting a pod in side the air box to hide it and cutting away a bit of the airbox for ventalation, but i dont know weather it will be worth the trouble.
Any information will help
thank you.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/
use the search function on the site, there's heaps of info on this topic.
I have replaced my blitz pod with a k&n panel filter in the stock air box, and havent notices any difference in performance. I've done this as i'm upgrading my stock intercooler and want to keep everything legal.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394377
thank you.
high-flow panel filter in standard airbox is your friend...
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394391
Pannel filter in airbox is good but when I put my cooler on I could not put the CAI part of the airbox back on because the piping was in the way so it was sucking hot air. I put a Apexi pod on, partitioned it off, and ran a cold air feed from the front bar to the older cooler piping hole under the pod. Made a difference in my case.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1394900
Just curious, I was at the autosaloon and they were selling ARC box filters.
Would this be legal in NSW? or would it be treated just like a pod filter?
Obviously any police seeing an ARC box would know it's not standard.
also are they any better than pods?
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395407
this is how my car is, no snorkel due to fmic piping, so i too have bought a pod and when i fit it will box it as you did.
so it did make a noticeable difference? small or big? i will be using an apexi pod as well so im interested since its the same situation.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395413
I have only had it on for a couple of weeks difference in performance is small but there is a lot more induction noise witch I like. I have noticed a difference in fuel ecconomy. ;)
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1395481
  • 3 months later...
since i posted last i fitted an apexi pod with cold air partition, and report back that it made very little difference when compared to a stock airbox without a snorkel.
actually, if no one told me that it had changed, i doubt i would have felt a diff at all so NO difference.
main difference is in the sound, it is extremely annoying on the freeway and i want to get rid of it on long trips :P
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575746
You can have any kind of filter you want, providing it is in a box of some sought. There was a mssive thread on here about CAI and airboxes, i think the results showed the pannel filters flow better, i may be wrong, but im pretty sure that was the case.
Good luck!
In Vic you cant have an oiled filter. But a pod doesnt have to be in a box. But you cant have a pod and an intercooler.
It would help if you say which state you are in before you ask questions about legality of mods, as all states have their own rules.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575777
ive just installed an arc box in mine replacing the old box and performance wise picked up some mid range. but after a while you can feel the car suckin in hot air. only way around it for me is to chop and modify the original snorkel for some cold air induction.
https://www.sau.com.au/forums/topic/76024-pod-or-air-box/#findComment-1575796
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
