i had clear covers over my plates and with the old cameras it just blanked out white, no spray or nuttin.
new camera's different story.
but there is this holgraphic stuff you can put over plates which looks fine from the rear but at 45 degrees its blank
I've seen this stuff on cars - SO SO dodgy when you drive past them. First time a cop sees it, they'll more than a little upset
the spray doesnt do shit its been tested and tried no matter what spray it is..
but the clear platsic plate u put over the number plate at a 45 deg angle works but it sticks out like dogs balls ...hahaha and if a cop see's u they will rape u for it!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
