What would in your opinon be the cheapest way to build a 10 second car.
The only rules are:
- Cost of the 10 second car must substitute in the cost of the car and the mods.
- No major weight reduction mods
- No blown carburettored V8's
In my opinon I believe the GSR Lancer would be the best candidate for building a 10 second car as its a relatively cheap car to buy, 4wd and has an abundance of aftermarket kits to build on it.
https://www.sau.com.au/forums/topic/76558-cheapest-10-second-car/
Old mazda 808 with a 13BT and old school T04, microtech, shortened 9inch, supra 5 speed and custom tailshaft with 8 inch slicks jammed under the rear end with some suspension work.
Total cost would be about 17k including car
I am up with that for sure the cheapest way to build 10sec package is just the way hes said, but put a T66 (with large exaust wheel) on instead of the T04
Mate is almost finished with his 13bt in 1300 wagon with the large port work and the T66 i cant wait till its run in and i get to have a go
I know you mentioned no blown v8s but the cheapest is definately a vb or vc commodore.
-THe car= $1000 in pretty good cond
- Motor= $4000 308 with a stroker at least 355
- Tranny=$3000 tricked up manualised auto
-Diff= $2500 9 inch with 4 link setup
- Wheels/tyres and miscalaneous= $2500
All up $13000
ANd if you want to go injected, add another 2g.
But rotary was my second choice its just the base cars are worth alot these days!!!
yea i knew a guy with a rx2 with a 13b in it it wooda been near 10s and it was cheap for him motor was 6k worked off its tits then shell was just about nothing nothing
then he got a r100 and put the motor in that
other guy i know has a V8 in a Ford Capri its a ex drag car does 11's had huges wheels on the back and motor coming out the hood
if he superchargers it it will do 10's
Go the rotor in a lite car :cheers:
The other cheapish one would be a 1GGTE with a big turbo, good tune, in something small. The stock bottom ends are unreal. To get a bit more go out of them use a supercharged bottom end, as they are 0.5 compression ratio higher, and can still cop massive amounts of abuse. Full motor would be about $700-1000ish now?
But yeah, carby V8, cheap as, or Rotor. 10sec car isnt that hard, but a reliable street driveable one is a bit more of a trick.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
