Love these...still available?
VOLK GT-C 19x10.5 +21 all round.
Potenza GIII rubber with 9mm tread. IMMACULATE
Perfect package for an R34 GT-R or similar
Closing August 13th
$4k  (caps $100 extra)
  • Replies 345
These have been relisted by the seller. Assuming the previous buyer pulled out. Volk GT-C with Potenza GIII rubber. *** listed two posts above ***
Closing October 1st.
WORK VS-KF 19 inch!!! R32, R33, R34 GT-R
19x9 +21
114.3 5 hole wrapped in Pirelli P-Zero nero rubber.
2500 kms total travel.
not often seen in this condition.
Closing October 14th
estimating $2600 - $3000 delivered.
  • 4 weeks later...
Charles,
since you have not connected me for over a week and won't answer my PMs
can you please give me more information here about the rims I have ordered.
The auction closed 30th september and has arrived in sydney and landed in sydney on 12th nov and still haven't got them yet.
white TE37 17x9+22 $3100.
Michael
Charles,
Michael
Michael,
Ya got a PM regarding your new shoes. they are here and very much landed.
all good!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
