Hey im bored and got money so i have decided to sell my 32 n1's turbos for a nre b/b set of either 34 n1's or something else prob is what is something else im looking for something that will bolt on the factory ppostion but if i dont go for the 34 n1's something that will make more power, not to worried about lag so i was considering maybe 2540,s with a set of cams would this be wise...
and question how much are 32 n1's worth these days..
A/r 60 steel wheels
https://www.sau.com.au/forums/topic/77419-32-gtr-turbo-selection/
I'm doing something different......mainly due to a few people getting pinged for import duty on Turbos thru Nengun and the like atm.
Anywho I'm getting my standard turbos rebuilt using Steel T28 Wheels, and having the Housing Machined, costs just over $1000ea to perform....should see 600fwHP which is probably 100hp more than i'll ever use :)
Did the same thing to my old 'VLT T3' was good for almost 400rwHP, and is still going strong after 2+years.
I will post results when complete
I got my GTSS through nengun! and a whole stack of parts... no duty or GST!
I wouldn't go running around advertising that fact. Regardless, you have to at least budget for the possibility when buying from Japan (US is a different story post free trade agreement).
I wouldn't choose the GT-SS's if your after more power than the N1s. I would choose at least the 2530s. 2540s = a mismatched turbo, so avoid (do a search for more info).
Lucien.
Is it possible to see a modified version of that graph with rpm instead of speed ?  I'm interested in the response of the 2530's but I'm not sure about the GTR gearing.
Dyno's charts are done in either 3rd or4th gear which is 21.9km/h per 1000rpm & 28.5 km/h per 1000rpm respectively.
The larger 0.6 AR front N1's are good for more top end power. I have the plain bearing group A's and at only 13.8 psi they can make around 400hp at the treads easy with cams (I have detuned my engine for a safe 370rwhp). If you wack the boost up to 20 psi with a better intercooler you could see as much as 500+rwhp. At those levels your engine needs to be made stronger and even before that an oil cooler is nice to have.
I'm running 700cc sard injectors, cams are tomei 260's and standard airflow meters. The Standard airflow meters run out of resolution over 400rwhp and it's easier to tune with something bigger like the Rb20/25's and they are a straight plug in. If you are shooting for more than 500 then Z32's are the shot. If you have the 0.6AR front N1's you should be able to get more out of it with bigger cams.
i'm running the gt2560r garret 320hp (r34n1) they have 0.60ar compressor and 0.64ar turbine housing and with pfc ,z32afm ,700cc sard injectors and poncams i make 529.4rwhp at 20psi .The gt2560r are very similar to 2530hks with the same turbine but has a differnet compressor ( i my opinion an awesome turbo combo for the gtr).
The 2530 hks is also an excellent unit also.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
