what is this?
i have a 1993 nissan skyline gts4
the reservoir in the boot on the drivers side?
what exactley is this for?
and what fluid do i top it up with?
i believe it is for hicas and requires power steering fluid
peoples??
cheers matt
ATTESA fluid resovoir... youre meant to use "Nissan Special Power Steer Fluid" which is also known as "Nissan Matic D" (auto trans fluid). You can get it from any Nissan dealer. When the system is pressurised, the fluid level is meant to sit between the min and max levels. Theres a fuse you can pop to pressurise the system, but I find if I start the car and drive it for 5 mins then check the level, its sucked down quite a bit and then I top it up. Your also meant to bleed the system using a nipple near the transfer case to remove any air from it.
 Share
