I can get 7 AP engineering power fc to suit R32 GTST for only $1120 delivered each.
This price doesnt include the hand controller.
If you require the hand controller then the total price is $1440 delivered.
These are ready to be shipped as soon as each payment has been made. No pre order, no waiting.
Come with 12 month warranty
This is only available for a week or if the 7 units sell by then.
Close date - 29/06/05
Buyers
1/ private buyer - Paid
2/ nF - Paid
3/ $$slowmedown - Paid
4/ B0oStEr - Paid
5/ nytrda - Paid
6/ - - - -
7/ - - - -
https://www.sau.com.au/forums/topic/77926-r32-gtst-ap-power-fc-group-buy/
  • Replies 42
Hey Paul,
Im very interested in one for my R32 GTS-T, But before i hand over any money can You answer 3 simple questions for me:
1) Are these brand new??
2) Is there an A.P Engineering power fc Key Ring in the box??? as i heard thats a bonus of this version.
3) can you quote the modle number of the A.P Engineering power fc for me.
Thats and excellent price, best i have seen by a few hundred.
Thanks
Greg
Hey Paul,
Thanks
Greg
Hey Greg,
1) Brand new with 12 month warranty
2) Not sure but will find out.
3) part number - 4E14N07Z
Price bump!
with commander - $1420 delivered.
without commander - $1115 delivered.
First 7 confirmed payments are ready to be shipped.
Payments can be made instantly and the units will be shipped as soon as individual payments have been received.
The power fc pro is designed for drag racing use.
These units have 2 additional functions over the regular units:
1. Ignition cut used for rev limiter - Regular Power FC cut fuel feed when the preset rev limit is reached. At high rpm there is the possibility of knocking when the fuel is cut in high powered cars.
The Power fc Pro cuts ignition at the rev limit to prevent knocking that could potentially destroy the engine.
2. 0km/h rev limiter setting - Allows for the setting for an initial rev limiter that is active whilst the car is not in motion.
This allows for maintaining a rpm level for constant launches.
:rofl:
can u use a hand controller from a 33 or is it different
Confirmed - The R33 GTS-t commander will not work.
ECR33 H/C- P/N: 415-X001
RB20 DET AP Version H/C- P/N: 415-N001
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
