Does anyone know whats happened to my car :
today I was driving and it started to get hard to select gears ... until the point where I couldnt get it into any gear at all.
As the car has a heavy duty clutch, the pedal is normally very stiff to push in, but now there is hardly any resistance at all.
The only way I could select first when the car was stopped was to turn the car off, select 1st (the gearbox was free to move with the engine off) and then turn the key. The car would bounce forward and then start. When driving I could get into gears but I had to really force it in.
So basically the clutch is constantly engaged and when I stop the car stalls. What the hell is going on?? How do I fix this???
I've checked the fluid levels and they seem fine. :confused:
I'm stuck and it's xmas day and nowhere is open and this is ruining my day ;)
cheers.
https://www.sau.com.au/forums/topic/7844-help-my-car-is-broken/
I got the RAC out and the guy thought that maybe the clutch master cylinder might be stuffed? Either that or the slave cylinder?
Either way it seems as though the problem is hydraulics as I can change gears when the car is off.
This is very annoying. ;)
Guess I'll hafta get someone to look at it on Friday then.
That's exactly what happened to my clutch a few weeks ago.
I had snapped the ball joint on my clutch pivot fork. What this effectively did, was move the friction point to a point further than you could access by pushing the clutch pedal in, so in effect, you couldn't disengage the clutch by pushing the pedal anymore.
I have checked the slave cylinder and the little piston on that moves when you push the clutch in, so apparently that means the problem is inside the clutch/gearbox.
I spoke to gtrken and he said that I could have done something similar like break one of the fingers. I'll get it checked out on Monday when I can finally get the car to a workshop.
Of course this has to happen now when all the shops are shut for christmas/NY!!!
Is there somewhere else there could be fluid other than in the clutch master cylinder?
Also when I press the clutch the slave cylinder moves in and out.
Does this mean I still have pressure within the hydraulic lines?
Dude, it does sound like there are problems with your clutch pivot point, or the mount for the slave cylinder, esp if it is moving - this is 'old school', but in my younger days the slave cylinder was usually fixed and pushed against a fulcrum which was attached to a pivot point. If you are not leaking fluid - it probably aint a leak, and you would probably know if it was.
I have heard that heavy clutches can do a bit of damage to the pivot point on skylines, specifically if the clamp pressure reaches or exceeds 3000lb - but that is hear say.
Originally posted by Steve
If you can get the damage welded, not too bad.  Otherwise you may have to replace the bell housing - don't know how much one of those would cost.
how the hell could this have happened?
i was driving like a grandma at the time!
The stress from simply pushing the clutch down on the hard clutch.
I had a VS V8 Manual Commodore previously which had a very heavy duty clutch. (At traffic lights your leg would shake)
That stuffed the pedal box and caused the pedal to click and clunk.
Put a new lighter clutch in (standard) and it was stuffed.
I was told I had to replace the pedal box and pin or some thing.
SOLD THE CAR!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
