if you put it on a scooter or lawn mower i would say it'll work fine providing you limit boost to no more than 1.5-2psi and keep the revs below 2000. if you bought it for your car you should have a responsible adult remove your credit card from your wallet and close your ebay account.
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1433984
the issue that ive have heard (not saying it is or isnt) is that the wheel isnt properly balanced which is causing it to loose a wheel under load.
Maybe getting it fully rebuilt or atleast checked by a local specialist to see if they can find something with the turbo before you bolt it on...
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434444
i reckon it would be a good upgrade on our old excel or maybe my daihatsu 1.6l NA engine. give it to me and i will tell you how it goes. hell if it works i'll even let you do some burnouts in it.
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434511
Hhhahahahaaa :)
I think the guy just needed to make a mistake to learn that he should research products before buying them.
Dont take it to heart man just get rid of it buy a proper unit and move on..
ps: make sure your buying quality next time ;)
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434512
you cut the corner by buying a very nasty turbo, and you want to cut the corners again by getting someone to balance it cheaper?
If I were you, I would try and sell it to buy a garrett or HKS unit. But the time you balance it etc, It might only last a couple of months.
Cheers
Sumo
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1435976
