  • Replies 98
Whats wrong with the place around the corner form last time?
They let you get away with murder in that place....speaking of which, where is Tom, hes about the only one that will put up with my table manners:)
COME ON TOM...where are ya?
....and Geoff, dont do the rest without me mate...give your back a chance and give it a few months to get the muscles around it to provide some support.
Running a bit low on time & money at the moment mate. I'll try to come up saturday morning to watch and maybe flag, but i wont be entering and wont be staying in Benalia for the weekend.
Looks like i won't even be able to make it to Bell's for the meeting tonight. :P
Hey, crazy Frank and myself are both in.  We're staying up there on Friday night.  We'll have to catch up for some drinks me thinks.
ps: How do I lose the wwwrxxx nic and switch to Thirty4GTR?
Wanna be known for who I am !!!
Aaron - Duncan changed my user name for me - go post what you want in here http://www.skylinesaustralia.com/forums/sh...ead.php?t=75309
I'm not racing now. Just not in any fit state and too drugged when I am feeling ok. I'll see if I'm up to the drive up to cheer you on but I can't prep the car feeling like this. Alcohol doesn't mix well with this drug either so no overnighters either.
Really pi55ed as I was looking forward to some fun.
