Hi SK,
Just back from Angola and have measured the springs as you suggested.
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
2 progressive coils.
Ps also found the front sway bar is broken not sure how long that has been like that and i guess would not be helping with the loose rear during mid corner.
King Regards
Edited by tacker
  • Replies 378
Hi SK,
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
King Regards
Front is ~400 lbs per inch (7.1 kg /mm)
Rear is ~370 lbs per inch (6.6 kg/mm)
Yep, a broken front bar is not good for rear end stability.
:) cheers :laugh:
Cheers SK,
If your ever in this part of the world you have a night of free beers.
I am thinking that i still might need some softer springs in the rear, what would your recommend?
Regards
Hi SK,
I have some measurements here, hope you can help me out to figure the spring rates.
I.D: 90/79
O.D: 12
# : 6.650
Thanks SK :(
Sorry for the delay
270 lbs per inch (4.8 kg/mm)
:P Cheers :(
Hey sydneykid im getting new coilovers for my cefiro soon but would like to know what rates i have at the moment, these are the coilovers that it arrived in oz with, measurements are
front
coil OD - 85mm top and bottom
wire OD - 12mm
No of coils - 7.9
rear
wire OD - 11mm
No of coils - 7.25
measurements taken on the car without verniers so may be a bit rough, thanks heaps
Sory for the delay, I missed this one.
Front is ~ 500 lbs per inch (8.9 kg/mm)
Rear is ~ 415 lbs per inch (7.4 kg/mm)
:P cheers :(
Edited by Sydneykid
Couple to calculate please -
1. Coil ID = 98/66 mm
Wire OD = 11.75 mm
# of Coils = 7.25 turns
2. Coil ID = 96/71 mm
Wire OD = 12 mm
# of Coils = 7.75 turns
Thanks
1. 235 lbs per inch (4.3 kg/mm)
2. 225 lbs per inch (4.0 kg/mm)
:) cheers :
Hi Gary,
Got some measurements...
front:
WD: 13.8mm (???)
turns: 4.75
rear:
WD: 11mm
turns 7.25
cheers
Ben
Front = 160 lbs per inch (2.8 kg/mm)
Rear = 200 lbs per inch (3.6 kg/mm)
:) cheers :D
Hi gary,
I've got one for you.
Rears:
coil OD 91mm
wire OD 13mm
coils 9.4
length (lightly captive) 247mm
Fronts:
coil OD 90mm
wire OD 13mm
coils 7.75
length (lightly captive) 190mm
thanks very much Gary.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
