c'mon gary. Put me out of my misery! I'm dying to know!!! hehe.
thanks mate. :)
Sorry, I am not at my engineering computer, I will do it as soon as I get home tonight.
:P cheers :P
  • Replies 378
Coil ID = 100/105 mm
Wire OD = 13 mm
# of Coils = 9.5/10 turns
Spring rate = ???
Thanks ...
135 lbs per inch (2.4 kg/mm) if it 9.5 turns and 125 lbs per inch (2.2kg/mm) if its 10 turns.
:D Cheers :(
Hi gary,
I've got one for you.
Rears:
coil OD 91mm
wire OD 13mm
coils 9.4
length (lightly captive) 247mm
Fronts:
coil OD 90mm
wire OD 13mm
coils 7.75
length (lightly captive) 190mm
thanks very much Gary.
Sorry for the delay, I haven't been at my home office PC since last Thursday.
Not too bad;
Rears are 185 lbs per inch (3.3 kg/mm)
Fronts are 245 lbs per inch (4.4 kg/mm)
:D Cheers :(
Edited by Sydneykid
woah! that is a long way off what i thought. maybe i measured something wrong, but i'm pretty sure i wasn't legless when i measured.
thanks mate. :(
thanks mate. :P
OK, ignore that. I just noticed you measured coil OD not ID. I will redo them tonight, sorry.
:( cheers ;)
Hi gary,
Rears:
coil OD 91mm
wire OD 13mm
coils 9.4
Fronts:
coil OD 90mm
wire OD 13mm
coils 7.75
Lets try that again, using the correct ID this time
Rear = 440 lbs per inch (7.9 kg/mm)
Front = 565 lbs per inch (10.1 kg/mm)
My suggestion for a cheap fix, stick the rears in the front and buy some 250 lbs per inch (4.5 kg/mm) rears.
:D Cheers :(
Gary, couple more please -
Coil ID = 102/88.5 mm
Wire OD = 12 mm
# of Coils = 6.1 turns
Spring rate = ???
Coil ID = 102/92 mm
Wire OD = 13 mm
# of Coils = 8.9 turns
Spring rate = ???
Coil ID = 99/68 mm
Wire OD = 12 mm
# of Coils = 7.25 turns
Spring rate = ???
Thanks
Wire OD = 12 mm
Spring rate = 225 lbs per inch (4kg/mm)
Coil ID = 102/92 mm
Wire OD = 13 mm
Spring rate = 170 lbs per inch (3kg/mm)
Coil ID = 99/68 mm
Wire OD = 12 mm
Spring rate = 245 lbs per inch (4.4kg/mm)
Thanks
:P cheers :(
  • 1 month later...
Coil ID = 66mm / 96mm
Wire OD = 13mm
# of Coils = 8.5 turns
Just a set of std fronts for an r32. Just like to know what they are rated at ;)
275 lbs/inch (4.9 kg/mm)
Which isn't standard R32GTR front, maybe check the dimensions again.
:P cheers :)
r32 gtst springs they are. The previous owner had them on my car to put the car at std height.
What would this pair be good for? (besides raising the car up :P)
That's an OK front rate for a GTR that sees a bit of track work, would need some decent shocks to control it. From what you are saying the height might be the problem. Some Bilsteins with the additional circlip grooves would handle the rate and then the height could be fixed using the lower grooves. But the Whiteline springs are only $144 a pair on the Group Buy and they are the right rate and height.
:) cheers ;)
  • 4 weeks later...
I have two sets of springs for you to check out please.
First set:
Front: Coil ID: 116mm
Wire OD: 13mm
# of coils: 6.5
Rear: Coil ID: 90mm
Wire OD: 13mm
# of coils: 8.125
second set:
Front: Coil ID: top 103mm - bottom 106mm
Wire OD: 12mm
# of coils: 6.5
Rear: Coil ID: top 70mm - bottom 65mm (this spring starts small, tapers out, then tapers in again)
Wire OD: 12mm
# of coils: 8.8
I appreciate your time. Hope to hear from you soon.
Regards,
Beau
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
