I have used both the ppg and the PAR gearsets, the PPG full set in a skyline and the PAR 1-4 gear set in a WRX both with dog engagement.
I think people are looking at two very different aspect here, whether the engagement is harsh or the gears are standing up to the power.
Harsh changes will result in breakages, there is always an upper limit of anything, dog engagement allows flat enaggement with less risk of give and additional strain on the gear sets. The gear set themselves then also comes into question, including the metallergical treatment that they have under gone and the design of the teeth.
Everything is a compromise, and you need to get a box for the application, a dog box will be driveable on the street, but not really in traffic...
Also the Series 3 GTR boxes are still prone to breakage in third, I have seen one do it after hearing that the series 1 it replaced was weak. The fact is the gear changes were the killer and as it was still using synchomesh this was placing additional strain on the box and gear sets.
I would also like to hear the reason behind saying PPG are crap...
  • Replies 56
What is this comment based on? Anything to explain why you said this as i am sure everyone is curious why you are claiming them to be rubbish, i sure am.
I don't know anything about these gearboxes so i am just interested to find out like most other people here.
Also, about the ikeya shifters, i read in hpi i think that they are slower shifting and more awkard then the stock shifter, great idea but just seems they didn't get it 100% right.
Oh and not that it really means anything but I WIN is running a Pfitzner gearbox in his 33 GTR now, might be worth asking him how its handling the power. If you want to pm him his username on here is MR33.
Yes mate - experience
Mate ordered the PPG full dog for his rex - after waiting a eterinity for it - the dog gears did not seem to be of the best quality - with seemingly having imperfections. He returned the box back to PPG (didnt even fit it) and awaited them to fix it. When they returned it - same thing again. Ended up refunding him.
Hi guys
for what its worth, i am currently using a ppg gearbox, straight cut dog engagement and love it. has been very good so far with no problems. on the dragstrip and for circuits also picked up around a third of a second down the 1/4
to get the car inot the ten second bracket.
it is noisy being straight cut, but the gearset was a work of art and the selector forks very strong. i have also been crewing for a team in the australian rally series
over the last couple of years and the ppg box in the group n car performed without fault.
i am very hard on the transmissions if that is anything to go by, 6500 to 7000
grand launches on the last two rallies comprising of 20 odd stages or more each rally.
cheers russell
IMACULA8 how long ago was this set sent to you...
I have only seen PAR sets in a WRX and not PPG, so I will ask around some more, but the ones we have used in skylines and the sets in silvias have been faultless. the WRX box also allows easy install of dog enagagement compared to other boxes due to the design...even though the output and input shafts are weaker than a druggos arm...
All very interesting.
The comment about a ppg being crap based on some ones oppinion that the gear sets were imperfect is a little hard , particularly as they were never installed and put through their paces!
PPG what doe's this stand for, Pfitzner - performance gears, satirical question if it's correct.
The general concensus on the PPG appears to be that they are not bad at all and affordable to the average ( keen ) man on the street ( not draging , it's an expression only ).
Ok the Hollinger seems to be the "Ducks nuts " but ut should be for the $$$.
The TRUST box.
Six speed - H pattern, likes revs and not torque ? Any of the above box's behind 700 horses of torque , rb 30 bottom end or simmilar 3.0ltr or bigger torque characteristics?
Wonder how the Trust would handle that against the PPG ?
ppg straight cut dog box with big input shaft and molly selector forks is the go...
handles 700 hp at all 4 wheels and 8400rpm launches with sticky m/t drag radials..
my gearbox has done about 40 passes high 9s and low 10s...
inspected gearbox internals last month and was all good....
cheers. mark
cheers. mark
Hi Mark,
How did you find your 6 speed getrag box as i'm not really in this hp level only running mid 500's rwhp and looking at other opinion from the std r33 box.
Got Aaron coming to bunbury to some tuning at Adrenline performance will be interesting to see him in action as it seems his worked on some very impressive equipment including your gtr i believe yeah. He had told me you guys had a good run out of the getrag 6 speed while running the R34.
And his even put us on to the CP piston range that you guys run (looks like nice gear) hoping will be picking up a set on the wkd for RB26 for a rebuild i'm doing.
pete
I know this box isn't in the same league but has anyone seen a 6 speed getrag break as was talk to the tuner of markr34gtr cars and his opinion was they were a pretty good box there not running it now in the 9sec drag car but they used and abused it for sometime with no problems. It just i'm considering going this way as my requirement arn't at suggest a high hp level and it seems the getrag is strong than the std 5 speed.
pete
ps anyone wants to unload a getrag let me know cheers
Pete,
I'll just add my 2c on the getrag 6 speed. As Troy mentioned I busted mine (twice!) and they are damn expensive things to repair. Luckily I have a handy man in the area to help me out and keep costs down a touch.
But I can also tell you that the gears themselves are strong as. And for dragging purposes I don't see them as a real weakness compared to track purposes. Both times I've wrecked mine have been on a big down-shift. Not an up-shift. Because its not the main gear teeth that gets broken - its the TINY shift drum locater teeth on the side of the gears. Basically when going from low rpm to high rpm on a down shift on the track the synchro's struggle a bit if you try and engage gears too early and can easily knock the ends of those teeth off. (When I say engage I simply mean clutch in and just positioning the gear leaver into whatever gear - not even engaging the clutch) If that happens forget getting the car into that gear above 3,500rpm.
Having said all that I've now consequently modified my down-shifting habbit's and the box has stood up well to a lot of abuse so far this year (touch wood!!)
Sorry for the hijack.
Hi Mark,
pete
never had probs with the r34 6 speed used redline mt90 gear oil...loves the stuff.
even with the cee s short shifter never crunched gears even flat shifting...
car was making 572 rwhp and ran several 10 sec passes...
but the ppg dog box is the go.....for racing...
i use cp pistons and had good results with them in the r32 race car.....
cheers. mark
Cheers guys thanks for the info
It sounds like the main gear set is strong and up to the task BUT the synco's might be the weak link. I might talk to a few gearbox specialists as was once told that synco in the 5 speed std box could be altered to give better shifting and reliability MAYBE they might be able to do something to help the 6 speed aswell. And i have also found no better gearbox oil than redline i run the redline light weight shock proof.
pete
pete
I think i have made a decision gentlemen , PPG is the box for me .
Thankyou all for your input and sharing your experiences with us.
"Kiss the ground"
And you chose PPG because...? ;)
Lucien.
I new some one ask that!
My answer -- purely on high hp owners experience, it's certainly not cost orientated.
Now ! Today a spanner has been thrown in the works, PAR has been talking to me in regard to there box.
Nearly half the price and offers similar gear aspects, claim that they have many box's with 1,2 3 dog and helical cut in 4 and 5 in for quiter cruising, in 1000hp cars in Australia and mainly Japan.
Can any one comment or ratify this. Are they a good box, i noticed that the main shaft is not larger like the PPG. Samm from PAR claims that he has never had a main shaft break ???
Im confused by what you say... Do you mean 1,2,3 straight cut, with 4 and 5 heilcal, and all are dog engagement. Or do you mean 1,2,3 are dog engagement with 4 and 5 syncro I think there is some confusion here with straight/ helical cut gears, and syncro/ dog engagement. PPG also do a 1-4 gearset replacment, that gives you dog engagment on 1-4 but with helical gears, and you just retain your 5th and reverse.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
