I bought the innovate lm-1 kit to tune the afr with the datalogit.
It interfaces easily to one of the 0-5v analogue inputs and allows you to plot average afr for each load cell. Very easy to tune with.
I do the same with the tech edge...also too easy.
Hey BMX, hows the wrx catch can?
After finishing the current tank of fuel I was on I managed to travel 402km's on a full tank. This is a significant increase in fuel economy. The wideband tuning was done when my fuel tank was just over 1/2 used and the ODO was on approx 220km's when we had finished wideband tuning. I usually get approx 330km's to a full tank.
I will see how it goes next week as I have just filled up today. I expect around 450km's to a full tank which is a massive improvement.
Thanks to all of those who have offered help and assistance.
The PowerFC guide will be updated in the next few days to include the wideband on road tuning and how to do it.
Paul I reckon your problem lies somewhere else. The stock ECU and Powerfc should give about the same fuel consumption if you dont hamer it much. You wil be in closed loop most of the time - relying on 02 sensor reading.
Are you getting around 14.7AFR at idle and whenever car is in closed loop?
I was getting about 400-450km to a tank (about 11-12L/100km) without the powerfc tune. When stuck on the dyno the AFR went into the 9s at full throttle.
Since the tune I got about 460km to the tank (10.6L/100km) but I reckon if I stayed off the gas then I don't think there would be any difference in consumption. The timing down low doesn't give you much benefit in fuel economy. I think a wheel alignment might give you more if you have too much toe.
You should check your injector duty cycles and air flow voltage at say 60km/h, 70, 80 and 90 in 4th gear (on the flat) and compare them with others on here.
Maybe you just sit in bad traffic or have a lead foot!! hehehe
no i wasnt getting 14.7 under normal closed loop, the whole close loop imho is a bit of rip i think, it takes so long for the stocky 02 sensor to give anything useful to the ecu about the afr's almost not even worth having it on.
when ive done a full tank im gonna turn off 02 feedback.
with proplerly tuned afr's i dont think 02 feedback will do anything other than waste calculating power. ive never had good economy on the FC until now, when i tuned the INJ map with a wideband sensor. before then it was always average is 320/330/340. on a full tank of fwy i would get maybe 400 if i was lucky. never ever ever over.
stock ecu economy was ok ish, not super great. not over 400 thats for sure
i do mild spiritied driving some of the times but the majority is light load / cruise. my inj duties however around 1.8% 2.2% on light cruise
I just came back from Bendigo taking it easy and i got 390ks before the light comes on. I generally can push this out to 450 before i fill up (love running it on empty) Last tank 434ks. I was quite dissapointed with the open road cruising as i took it easy and was only gettting 100ks every quarter of a tank. When we tuned it we concentrated alot on fulll throttle but didnt do much on light throttle since upping the fuel pressure so i guess its guzzling on light throttle. Im smoothing out the part throttles Inj cycle to try and bring a little more effeciency into it. Even with the bigger turbo i think i could still get 500ks on a trip but might need a dyno to see my AFR's at light throttle.
Im experimenting at leaning it out a little on light throttle but its all guess work until i get a monitor. Remember i could only be adjusting it 1% here and there so its really not going to make much. I hope i dont lean it out too far.
about to upload my current tune data and .dat files and also got the datalogit afr chart in excel so i can spit out my afr's apparently based on what the pfc inj map values you are (so it claims anyway)
attached fuel inj compare against last tune and also fuel map and also datalogit tune .dat file. rename .txt to .dat and use it with datalogit if you wish
paulr33_193rwkw_widebandtuneup.txt
thanks Robo for pointing that out, something i clearly missed.
I managed to get 504k's to a full tank of all hwy driving on the weekend,
This week is city testing, so far 100k's on just under a 1/4 of a tank.
Will update those 3200rpm cells, should be 1.00 instead of 1.070
460km to the tank at 10.6L/100km would suggest that you have only a 48.76L fuel tank.
To properly work out fuel economy you need to start with a full tank, resest the trip meter drive how ever many Km's you want then refill tank to full and compare your actual Km's travelled to the amount of fuel you needed to fill it back up.
My around town fuel consumption for my PFC tuned 25t is 15L/100km which would be 433km's on a tank (65 litres) full to empty.
I did the fill up reset the trip, then fill up again to get those readings. Thats the only accurate way you can do it. Not everyone is going to run it dry..I ran it till almost E and got 460km - no doubt plenty left - yes I put in close to 49L. You probably will never run it down to less than 5L unles you really push it.
15L/100km is horrid. To be honest though I havent really done much heavy traffic driving - I guess mine would probably go to 12-13L/100km then. They are only a 2.5L engine. If u use boost a lot then expect bad consumption.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
