  bmxwrx said:
I bought the innovate lm-1 kit to tune the afr with the datalogit.
It interfaces easily to one of the 0-5v analogue inputs and allows you to plot average afr for each load cell. Very easy to tune with.
I do the same with the tech edge...also too easy.
Hey BMX, hows the wrx catch can?
After finishing the current tank of fuel I was on I managed to travel 402km's on a full tank. This is a significant increase in fuel economy. The wideband tuning was done when my fuel tank was just over 1/2 used and the ODO was on approx 220km's when we had finished wideband tuning. I usually get approx 330km's to a full tank.
I will see how it goes next week as I have just filled up today. I expect around 450km's to a full tank which is a massive improvement.
Thanks to all of those who have offered help and assistance.
The PowerFC guide will be updated in the next few days to include the wideband on road tuning and how to do it.
Paul I reckon your problem lies somewhere else. The stock ECU and Powerfc should give about the same fuel consumption if you dont hamer it much. You wil be in closed loop most of the time - relying on 02 sensor reading.
Are you getting around 14.7AFR at idle and whenever car is in closed loop?
I was getting about 400-450km to a tank (about 11-12L/100km) without the powerfc tune. When stuck on the dyno the AFR went into the 9s at full throttle.
Since the tune I got about 460km to the tank (10.6L/100km) but I reckon if I stayed off the gas then I don't think there would be any difference in consumption. The timing down low doesn't give you much benefit in fuel economy. I think a wheel alignment might give you more if you have too much toe.
You should check your injector duty cycles and air flow voltage at say 60km/h, 70, 80 and 90 in 4th gear (on the flat) and compare them with others on here.
Maybe you just sit in bad traffic or have a lead foot!! hehehe
no i wasnt getting 14.7 under normal closed loop, the whole close loop imho is a bit of rip i think, it takes so long for the stocky 02 sensor to give anything useful to the ecu about the afr's almost not even worth having it on.
when ive done a full tank im gonna turn off 02 feedback.
with proplerly tuned afr's i dont think 02 feedback will do anything other than waste calculating power. ive never had good economy on the FC until now, when i tuned the INJ map with a wideband sensor. before then it was always average is 320/330/340. on a full tank of fwy i would get maybe 400 if i was lucky. never ever ever over.
stock ecu economy was ok ish, not super great. not over 400 thats for sure
i do mild spiritied driving some of the times but the majority is light load / cruise. my inj duties however around 1.8% 2.2% on light cruise
I just came back from Bendigo taking it easy and i got 390ks before the light comes on. I generally can push this out to 450 before i fill up (love running it on empty) Last tank 434ks. I was quite dissapointed with the open road cruising as i took it easy and was only gettting 100ks every quarter of a tank. When we tuned it we concentrated alot on fulll throttle but didnt do much on light throttle since upping the fuel pressure so i guess its guzzling on light throttle. Im smoothing out the part throttles Inj cycle to try and bring a little more effeciency into it. Even with the bigger turbo i think i could still get 500ks on a trip but might need a dyno to see my AFR's at light throttle.
Im experimenting at leaning it out a little on light throttle but its all guess work until i get a monitor. Remember i could only be adjusting it 1% here and there so its really not going to make much. I hope i dont lean it out too far.
about to upload my current tune data and .dat files and also got the datalogit afr chart in excel so i can spit out my afr's apparently based on what the pfc inj map values you are (so it claims anyway)
attached fuel inj compare against last tune and also fuel map and also datalogit tune .dat file. rename .txt to .dat and use it with datalogit if you wish
paulr33_193rwkw_widebandtuneup.txtFetching info...
thanks Robo for pointing that out, something i clearly missed.
I managed to get 504k's to a full tank of all hwy driving on the weekend,
This week is city testing, so far 100k's on just under a 1/4 of a tank.
Will update those 3200rpm cells, should be 1.00 instead of 1.070
460km to the tank at 10.6L/100km would suggest that you have only a 48.76L fuel tank.
To properly work out fuel economy you need to start with a full tank, resest the trip meter drive how ever many Km's you want then refill tank to full and compare your actual Km's travelled to the amount of fuel you needed to fill it back up.
My around town fuel consumption for my PFC tuned 25t is 15L/100km which would be 433km's on a tank (65 litres) full to empty.
I did the fill up reset the trip, then fill up again to get those readings. Thats the only accurate way you can do it. Not everyone is going to run it dry..I ran it till almost E and got 460km - no doubt plenty left - yes I put in close to 49L. You probably will never run it down to less than 5L unles you really push it.
15L/100km is horrid. To be honest though I havent really done much heavy traffic driving - I guess mine would probably go to 12-13L/100km then. They are only a 2.5L engine. If u use boost a lot then expect bad consumption.
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
