Hey guys i dont currently own a skyline but was looking into getting one......the two im looking at are the r33 and r32's gtst.....now my mate has a mkii falcon xr6turbo.......simple........i want to beat him.......the r33's look better (with the 400r bodykit which id put on) but the r32 is lighter if im not mistaken......ontop of the actualy price of the car i was not looking at spending more then 10-12k on mods to beat him......hopefully get into very low 13's or higher 12's on da 1/4....if this is not possible i guess i'll have to go EvoII
Thanks guys
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/
  • Replies 46
have to start of by saying metallica is the best band in the world
secondly, if ur mate a an XR6T you really wont have to spend a lot of money on either a r32 or r33 gtst to beat it. get an exhaust, cooler, fuel pump, injectors (or fuel regulator), chip the ECU and upgrade the turbo and you will hammer him. after all this you will have heaps of money left
and the debate of r32 vs r33 has been going on for ages. it all comes down the personal prefernce
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450912
The R33's run low 13's when an exhaust, fmic, powerfc and a bit of boost.
Some have even managed a high 12 sec pass with a well sorted rear end.
Grab your self a decent R33 with an exhaust and possibly fmic, drop in a powerfc and it will be running the times you want.
Providing you can drive that is. lol :D
Those XR6T's can launch pretty hard off the mark.
If you can't drive you'd better go the 4wd.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450929
Well i was thinking of if i were to get one....(r32 or r33) put in exhaust, fmic, sard injectors, fuel regulator, to4 turbo (dont know which spec yet but one with good mid-high torque/power with steel ball bearings), and either chip or full stand alone...plus cams and valve springs seeing as the head makes all the power.......also how much approx is it to rebuild an rb motor with lets say forged rods, pistons and balanced crank etc
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450938
screw gettin a Rex, ull get hammered shitless on the freeway by an xr6 turbo, plus not have as much cash left over for mods to try to keep up... dont want that. But as it was said, if your a bad driver the 4wd will help from the traffic lights and will give u a large advantage over him.
Get whichever you prefer looks wise as both the 32 and 33 will deliver fine especially if you plan on putting 10k + into power mods into the beast!! You'll be running low 13s easy as in both cars.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451152
Thanks guys
do you see the word freeway in there?
no
do you see the word 1/4 in there?
yes
will the rex beat a xr6t on "da 1/4"
yes
what car R33 v R32?
I prefer R32.
the money on mods that you say you want to spend you could build a wicked engine (doesn't have to be an rb20... go read the rb30 thread up the top of this forum)
that will destroy many a car on "da 1/4"
xr6t = 1700+kg
r33 = 1350 kg
r32 = 1260 kg
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451457
Providing you can drive that is. lol :cheers:
What cubes said.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451542
Then just get a big, heavy stick.
Seriously, decide what you want, then do it. With $20k to spend on a car and mods, youll be able to kill him.
My opinion, to really piss him off, get an R31 GTSX import (still eligable under the now 16 year rule) with an engine upgrade (either rb25 or rb26).
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452042
Look at tradingpost!!!!!
Why are you bothering getting a GTSt if you already have the plan to mod it. Start with a GTR.
R32 GTR's going for around 23K with a few goodies, saw a black one with N1 turbos and a claimed 250KW @ wheels (something like that).
Get something that already goes fast so you know what you are getting into the day you buy it.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452133
I am with psybic just spend a little more on buying the car and less on the mods a R32 GTR goes for around 22k - 23k with a few goodies and then if you have to just add powerfc, wolf 3d so you are able to fine tune then a fmic if doesn't have one. Little bit of boost you will eat him alive that way you get a better car in my mind and you might only have to spend 3 - 4k instead of your 10k
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452192
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
