I heard rumour from a good source at Ford, that they are currently developing an AWD system for the next Falcon. It is primarily the same drivetrain used in the Territory, but obviously modified to suit the Falc. This means there would more than likely be an XR6 Turbo AWD.
Now Im not a Ford fan at all, but I'll be the first to admit that an XR6 or Typhoon with AWD would be a lethal weapon. If released, would it have the potential to reach GT-R's level of performance and success? I'll be keeping a close eye in the rear view if it does!
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/
  • Replies 66
In the present future there is rumours of them putting an XR6 turbo motor in the AWD territory. In an AWD system it would be very very difficult to hold the amount of torque that the motors have the potential of making. Ford would have to make ane exceptional drivetrain in order to hold this sort of power.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455140
Ford, is currently using the territory as a test bed for it's awd system, but as someone here said getting the kilos down and the reliable drivetrain to cope with it will cost big dollars.
So even if it did comes out chances are a FPV only case, can't see it under $100k and on the wrong side of 2tones, I remmeber Holden once said, when they sticK an awd behind
5.7, then they'll teach the 2.0 litre brigade(wrx) a thing or 2, I'm still waiting. They've forgot one thing reall R&D cost lots of money and time.
Until now the turbo XR6 still show signs of being unreliable, god forbid what an AWD turbo would do.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455284
There have been rumours of that for a while from both the Holden and Ford camps..
I am not sure whether I can see it happening in a production car from them because of the cost, and being able to sell. Sure it would be awesome, but whether they can get the public to bite at $60k+ not so sure.
You have to remember also, that in places like Japan they can afford to throw millions more at development for fancy things as AWD, and trying many ideas that do and don't work during development, as they know they will sell XX hundred thousand rexes/liberties/evo's worldwide. Whereas in Australia, there just isn't that return on investment.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455963
BTW, the Nizpro Territory ran a 11.7 on the 1/4 recently
Yep a couple of records were broken that night, 11.7 for Territory:
http://www.fordxr6turbo.com/forum/index.ph...showtopic=18714
and 10.56 for an XR6T sedan.
http://www.fordxr6turbo.com/forum/index.ph...showtopic=18713
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1457935
Yeah, it might be a Ford, but it is also brand new and has a factory warranty.
While it is no GTR or Skyline, you guys are gonna want something that is a six cyl turbo in the near future and I bet a XR6T will be the top of the shopping list, I was so impressed I bought one.
$1500 in mods and I have a 12sec car that can carry 5 adults and their luggage:whatsthat
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1458162
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
