For anyone who is interested, I'm gonna be playing in the No Limit tourney at Crown 2nite. If you're interested in playing, there's usually bout 220 people there. Buy-in is $75 and you get $1500 in play chips. It pays 1-20 places and if you finish 20th, you'll at least get yr money back.
It's a hella lotta fun and I recommend it to anyone interested in playing against people.
Play begins at 7:20 I think but if you wanna get a spot to play, I suggest you don't get there any later than 6:30.
  • Replies 67
I'm sure myself & 46n2 will play..... I keep clearing everyone out of their chips heehee :P Shame we didn't play for $$ in Townsville.. would have come back rich..
I don't like gambling.. but since Mr professional is going to be a dealer I'm sure that won't be an issue.. :P
Anyhow I'm sure you lot have played alot more than I have so I guess it depends on the entry.. tokens. I'm always up for UNO too :)
James maybe you can teach Eva how to play (Fairy) Snap.. she can't grasp that you smack your hand down and scream 'snap'.. she just goes 'wooo' and looks excited! :cuss:
i'm in... if only to make sure ferni keeps his chips in neat lots *chip nazi*
you guys should have a separate dealer (ie not swapping players as dealers)...
haha don't let her play!!!, this is rush at the poker table:
"all in"
"shit haven't looked at my cards yet"
then "show me what you've got, im already out" hahah
"all in"
that's my 'poker face' :) i have a short attention span on a big table coz it takes too long... played fine that night at aaron's...
that's true... i still like to be involved in some way, all the time :)
i'd be a spectator, so dont worry... im on a strict allowance rember :)
I would love to join in. Every couple of weeks or so me and my mates play Texas Hold-em. For money of course. Its great. By the way do you have all stuff, such as chips and felt for a table or an actual poker table. Willing to bring me chips if needed i have 500. They are good quality to. Actual size and weight. etc. Depends what time/day?
Count me in also if possible, me and my mate looking into getting these official WPT decks and table, but have to find out about shipping and tax costs, if we get them in time i could bring em round.
double sided table, only $70 US
1000pce chipset with cards $400 US, bit more pricey.
Oh Leewah, u gonna make sure Shana Hiatt's there calling the plays?
Meh, came top 50 somewhere. Got bailed out when the blinds got too big. I hadn't won enough to see the blinds through so I put an all in on a K,6 offsuit and got done. Made silly mistakes at the start and lost a fair bit then but built it back slowly.
It was still lots of fun though. Still recommend it to anyone who likes to play and wants to gain experience playing No Limit Hold Em.
Maybe 1 day, you too can win $10M in Vegas :rofl:
Howd you go at crown the other day Leewah?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
