What use if any are those catch cans if they have no baffles inside them?
Baffles can be easily installed.
Lets compare these to the more expensive greddy and cusco cans.
They both come unbaffled and cant be opened to install a baffle.
And are around twice the price of the ones I have avaialble.
Even if you compared to a decently made can with baffling you are still out of pocket around $100
I stand by my products :D
  • Replies 72
hi, am interested in many of ur things....1 quick qu - will the large intercooler be a direct replacement for an r32 gtr.....could i take out my old stock cooler and put in the large intercooler using the stock pipes?
thanx in advance for reply....look forward 2 doing lots of business with u soon (the collection of my build up parts will begin soon)
:D
hey man im after the HKS immitation BOV, does it sound and work the same as the original?
Also was it you who sold high flow cats?
If not who was it, show me the thread.
Cheers,
SINDOWS
For the R33 GTST intercooler kits - do they require trimming of front bar and/or fan blades?
They are the same design as the hybrid kits where they require trimming of front bar and/or fan blades.
Cheers.
hrmm..  sent money yesterday to you gR33ddy and requested for u to let me know that you got it.  you should of got it today but you havent responded to any of my PM's.
Sorry for the delay - Ive been caught up with work commitments the last few days. PM sent :huh:
Still nothing.
Anyone received anything from this person?
This person has sold a couple of things on the forum - I lost count after 300+ transactions lol
Come on guys back me up here !!! :)
Also where are these kits supposed to be mounted.
I front or the radiator. Can they be mounted inside the rhf guard.
They can be mounted at either position.
Heres a link to a good install guide of the same kits in both positions.
OIL COOLER KIT
Cheers.
:unsure:
wat price can u do on the oil cooler kit but without the oil cooler. just need the hoses n relocation kit...
The core is actually the cheapest part of the whole kit.
Without the core they are $280 delivered aus wide.
Cheers.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
