Hi,
I put a cooler on my car approx 2mths ago and since then I noticed a flat spot from around 3500-5000 rpm. The piping is 2.5" back to both the standard piping
(ie routed behind the cooler). However, on the left end tank of the cooler (looking from front), I've got a 180 Deg Bend that was cut and modded (made it a mitred 180 Deg bend) to allow the bend (as i'm still using standard front bar) so i can route the piping behind the cooler. Would this be a problem for pressure and flow?
Also the size of the cooler is a 800x600x73 (i think 73 anyway). I've also got a 3" turbo back exhaust running 10psi boost.
Another factor is my coil pack were crappy at that very time as well and i have taped and siliconed them..No longer misfires but i have read that main "missfiring thread" and in that thread some people where getting flat spots roughly around that rev range.
As a result, my car is running slower than it was with just a stock cooler and 3"exhaust (9psi)
So is it my cooler size, cooler piping or is it the result of dodgy ignitor coils?
Any help would be great.
Greetings All.
I think you will find that the intercooler is too big...unless you DID mean a 600x300...other wise your cooler would be WAY too big for only 10psi...
Flat spot eh...over fueling issues...? Something to do with fuel or fuel delivery??
Cheers,
--Tonba
Why would the FMIC be too big?
They are essentially just a heat sink between the compressor and combustion chamber, so a larger heat shedding capacity = more reliable/greater power production.
I must say that my R33 running a 600 x 300 x 76 did suffer the std ECU flat spot.
Perhaps I'm missing something?
cheers
Your mods sound the same to mine.
I suspect your ecu is richening the mixture and retarding ignition. Time for aftermarket engine management.
Whack it on the dyno if you want to really see what's happening instead of just guessing though.
PFC plugged in with standard base maps immediately removed the flat spot - it did feel like ignition retard was the issue.
Perhaps a significant reduction in pressure drop (vs. the std R33 cooler + piping, + exhaust) means the engine was ingesting enough air to make the std ECU go into a fail-safe, even though the actual boost pressure was unchanged?
You have removed a restriction, therefore more airflow (boost is irrelevant). The AFM is sensing more airflow and telling the ECU (AFM's are blabber mouths, just can't keep a secret). The ECU knows that much airflow is too much, so it hops onto Rich & Retard mapping to protect the engine. Time for some tuning, DFA, SAFC, PFC or equivalent.:D
I'm suffering a simalar flat spot, after installing an EBC. I'm only running 9PSI but it gets there much quicker than before.
I'm guessing the computer sees AF/RPM. so in the mid-range where the boost is incresced it plays up but then over 4500RPM things are just about back to normal so she takes off again.
Well that's my theory........ :confused:
I'm hoping that playing around with the gain will help, if not i will be searching for a vacuum/pressure leak, and then look to the computer. Besides i don't have any money to buy a computer just yet!
You have removed a restriction, therefore more airflow (boost is irrelevant).  The AFM is sensing more airflow and telling the ECU (AFM's are blabber mouths, just can't keep a secret).  The ECU knows that much airflow is too much, so it hops onto Rich & Retard mapping to protect the engine.  Time for some tuning, DFA, SAFC, PFC or equivalent.:cheers:
I'm happy that my deductions about the std ECU were correct - it really means Nissan engineers defined fairly tight engine performance parameters, enforced by a fairly tamper-proof brain. I've gone down the PFC trail, but what degree of success could be expected with an intercepter (eg. Jaycar kit) that fools the ECU into accessing different parts of the factory maps?
cheers
Hi,
A mate of mine told me to clean the AFM so I cleaned and the car now seems to go alot better. I havent pushed it hard all through the gears (only 1st and 2nd) but the lag as mentioned between 3-5K rpm is now gone. I'll do more testing this weekend and let you all know the result.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
