Wondering how i go about adjusting my handbrake in R33. At the moment I'm having to give it a full erection to apply the brake and even then its not as tight as i'd like which kinda gets annoying.
I've had a bit of a look under there and its a bit different to other cars I've adjusted it on (which usually have a Y wire type arrangement). It looks kinda like
(ignore the dots, they're just spacers to get the diagram ok)
Now where those wiggle things are it looks a bit like a small adjuster screw. Couldn't find my adjustable wrench (don't u hate that!) when i got under there, but can I screw these in or out to adjust the tauntness ?? Or I notice that each goes off to each wheel with a bit of a bolt there - or do i adjust it there??
Thanks
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/
extremely easy mate. After you take off the boot, you will see a bolt with a nut on it on the pass side of the hand brake. Just keep tightening the bolt till its right. Some people have found that when they tighten it, the bolt comes too far forward and rubs on their hand brake boot, so you may want to cut the end of with a hack saw.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118794
A Hacksaw,,,,PLEASE,,,,this is a Nissan we are talking about,,,,put away the hacksaw for ever.
1/ Remove your back wheels
2/ There is a rubber plug on the rear discs that hides the ADJUSTERS,,,,much like a drum brake rear end on an older car,,,but it's on the front face of the disc,,,,spin the disc around till you find the adjuster,,,using a torch helps....
3/ You need a lever of sorts to click the adjuster around,,,.
If you are in any doubt,,remove your discs and have a look,,,,.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118968
Are you talking about inside of the car or outside of the car?
I actually have the centre console out at the moment 'cause i've been playing with it.. If its inside the car then all the better...then i don't have to climb under the car again (its kinda hard with just a jack!)
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118969
Thanx ndr...so its at the wheels. Ok, i'll whip them off soon and take a look. I did have a look from behind and saw where the cable went to behind the discs.
Its different to my old R31 but thats not surprising. With the R31 i did it mid-body underneath there was like a double screw thingo.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118973
Will you have the Console out,,,,,Back off the adjuster at the Lever a little bit,,,,Leave about 10mm to 15mm of thread showing,,,The Lever ones just to take up the slack,,,,.You can play with it later....
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118977
Yep,,,exactly,,,,JUST and I mean JUST touching while spinning the disc,,,you should be able to adjust them with the discs on though,,,,or did I mis-interpret you. After you got that done,,,go to the handbrake lever and just adjust it about a 1/4 of a turn and then lock it up. This will even out the play in the cables.....
Joel,,,how easy is it hey,,,.
Predator666,,,,how did you go???.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-121056
  • 4 months later...
  • 4 weeks later...
yer, this still doesn't make heaps of sense to me as i can't recall any sort of rubber access panel on the disc when i check the other day. i'll check again soon
predator666,,,when you remove a rear wheel,,,you will see 5 wheel studs,,,2 threaded holes and 1 slightly larger hole which should have a rubber plug in it. The rubber plug one is to do your adjusting. The 2 threaded holes are so you can remove the disc,,,BUT ONLY ever using High-Tensile bolts as a puller just in case it's a bastard to get off. Take a disc off and have a look,,,you will understand then what I'm saying.
Yes Moschops the inside of the disc has a braking surface and has Drum brake like pads in there and yes sooner or later they will need replacing.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-375438
  • 11 months later...
Digging up an old thread, but is this the same for my 32 GTR?
Ronin are you physic or something. I just walked in after adjusting my handbrake for this weekends motorkhana at Oran Park. I would think that an R32 would be the same,,,just do what I told the others,,,pull off the discs and have a look. In actual fact this is a great idea because you can learn which way the adjuster goes. LSD's are a pain in the arse,,,the wheel will not spin freely.
:thumbsup::):cheers:
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857040
:thumbsup:  :)  :cheers:
Neil.
Hey Neil, pilfering a pic from the for sale section (thanks BB GoDZilLa), is the handbrake adjust hole you are talking about the little black cap with the flat head slot set into it?
http://www.skylinesaustralia.com/forums/at...achmentid=16142
And what do you mean about the LSD? Since mine is a GTR, will I have to get the bugger up on a hoist so all wheels turn? :confused:
Thanks for the advice though! will tackle this weekend
-marcus
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857048
Yep spot on buddy. That slotted plug is rubber and yes it's the adjuster hole,,,Great steal indeed. Now imagine a front wheel drive car,,,it's easy the spin the rear wheels because theres no resistance,,,now try it on your LSD equipped car. It's much harder to spin the rears and that makes it harder to distinguish between the spinning of the wheel and the handbrakes shoes rubbing up against the inner discs. Just be a little conservative.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857147
  • 1 year later...
Diggin up an old thread, but I did this today, thought I'd take some pics to save confusion for people that don't understand written tut's as well as pics...
This is on a R32 GTST, but I can't see it being too different on other Skylines.
Directions
NOTE: If you want, loosen the handbrake off in the car first, this will give you more adjustment up there to make it easier later on.
1) Chock front wheels so car dont roll
2) take handbrake off (ie. as if you are going to go for a drive)
3) Jack rear of car
4) remove wheels
5) remove rubber plug (it's not in the photos..I already had it removed)
6) spin hub until you can see the gear to adjust (use a torch) but I am guessing all skylines would be in similar position to mine, so it's at about 5-6 o'clock
7) Stick a flat head screwdriver in the hole, use the hub as leverage to push the gear up or down to adjust. You will probably only need spin it a few times unless your handbrake is pretty much not working.
8) Use common sense, it's hard with the LSD, but you want the brakes just touching, then maybe back it off one click.
9) You did both wheels, didn't you?
10) put plug back in put wheel back on....
NOTE: If you decided to loosen the handbrake in the car, make sure you tighten it back up!!
Happy days.
Cheers
Chris
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-1492517
wow, nice gold digging....
btw, if the balance between left and right braking is ok,   if you just want to tighten the lever, see the second post in this thread,  that's all you need to adjust.
Sorry but I have to dis-agree. The Lever adjuster is hidden under the console for a reason. If you do the adjustment at the rears properly you should almost never have to touch the lever one.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-1492993
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
