Yeah anything R33 GTST won't fit the stock caliper/hub combination; they will machine down to the same circumference (remove 3mm off the radius, a reduction in diameter of 6mm) however offset is wrong. Too shallow; binds on the inside pretty badly. Same would go for all stock size R33 GTST front rotors which are the same type/size, I would assume, regardless of manufacturer/part number.
Edited by DaveB
so r33 gtst style rotors won't fit a series 2 then?????? shouldn't these be the same offset tho?
what the hell do we use then>??????? 33 gtr rotors?
WELL GEN NISSAN if you have money to ,other wise wait till someone find`s a setup may be may be look & see what you can find like most of us have been doing for 2 year`s ;) ,it`s hard work & when you do if something like brake pad`s :) it`s like WHY BOTHER ;) ,cheer`s chuckie.
Yep, exactly my thoughts, and it sucks but I don't think there are any, except for places direct from Japland like Dixcel etc. If you replace calipers too, and solve the bolt problem then R33 GTST rotors can be used (do *not* machine down diameter) or you can *probably* use R34 calipers and rotors... but wait for the verdict on those from someone who has done it first or see if you can borrow a set and test fit.
The ultimate solution, yes. Unless R34GTR ones are bigger or are a direct fit?
Of course if you change calipers too, you don't have to go GTR - even GTST ones are 4-potters apparently.
Edited by DaveB
Ok done a bit more digging and found these guys
http://www.japaneseimportspares.com.au/par...tegoriesbrakes/
They are agents for dixcel rotors they have series 2 fronts in stock non slotted for $295pr and he told me they can get slotted by order for around $400pr
Part #'s are
Front #321 2013
Rear #325 2016
Ive included the part #pdf for anyone who is interested
domesticcar_r.pdf
Part #'s are
Front #321 2013
Rear #325 2016
domesticcar_r.pdf
Good find! An Aussie Dixcel distributor :(
Although I would want at least slotted rotors, but at $400 even the *retail* price of a group buy on slotted rotors on these forums for R34 GT-T is nearly $50 less than that... personally I would upgrade but the Dixcels are still an option for those wanting to save the extra few hundred to buy calipers and get brakes fitted & bled (and probably to get the calipers rebuilt).
I notice the site you posted has a set of R34 front brakes (calipers and discs) for $600. So hopefully it is possible to pick up a set of calipers only for say $300 and get them rebuilt for ...??$ Then get some slotted (or slotted, grooved & dimpled) R34 GT-T RDA rotors through these forums, a set of R34 braided hoses through another group buy on these forums and you're all set. I would guess that with pads though it's around an $800 exercise if you fit it all yourself... with a workshop for fitting maybe $1,000 all up? Getting expensive. And that's just fronts... rears add another $600-700 for the same exercise? *guestimates*
ah i see, so gtst 33 calipers are essentially gtr calipers aswell, both of which are lighter cars then th stags, yet we get 2 pot calipers?
R32 GTR and R33 GTSt are the same calipers front and rear, i.e 4-spot front and 2-spot rears manufactured by Sumitomo.
f**ken OUCH
i use s14 RDA slotted fronts from the group buy on my 8/97 S1, but due for rears if anyone knows what fits?
Yup - nothing sold here in Aus...
I posted the part number earlier in this thread (43206-4P000).
The only car that comes close in an R34GT, but I don't think you'll find any of those around.
Well Hope that we can have some new`s to day As iam going to BRAKEBOND`S to see if they CAN MATCH GEN NISSAN rotor & see what they can do with price on Front pad`s will try to get better deal ???,
cheers,
gonna try the RDA group buy
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
