just bought some 2 pot rear calipers off a r33gtst for my series1 stagea, will get discs and pads next and then fit them. that's the back sorted then!! At the front I have decided to go for either the r34gtt or the r33gtst calipers and discs. I am running the standard 16" wheels. Will the 310mm r34gtt discs and calipers fit under this wheel or will I have to go with the 296mm r33gtst discs and calipers?
i trail fitted some R33 callipers to my stagea and found that the R33 fronts stuck out about 20mm further towards the wheel spokes than the stock S2 stagea ones. R34 ones i'd say would be about the same if not a little bigger. i don't have 16's so cant say if they fit over the callipers, but check to see if your rims have enough clearance for a wider calliper.
Edited by QWK32
Has anyone tried putting R32 GTST front brakes on a Stagea S2 RS4? I am looking at using my stock 16inch wheels.
R32 calipers require the same mods to fit as the R33 ones. IMO why bother though, they are smaller and older than R33 ones. And thinking about it I'm sure the R33 came out with 16" wheels standard so there shouldn't be a fitment issue with diameter, Just check there is enough disk clearance. FYI R32 rears are basically the same as R33 GTST rears.
found this site.
http://justskylines.com/skyline/knowledgeb...ake_setups.aspx
Useful info on there!
I have decided to go with r32gtr/r33gtst brake set up. That should fit under my stock 16" wheels, easier to get spacers if I want to up to 324mm discs and more available than r34gtt 310mm calipers so easier to source ( already done, just gotta save up!!) and a lot cheaper!!
Edited by airbox
I trial fitted some R32 4 spot calipers (They could be Z32 think they the same ???) on my RS4 Stagea S2.
They seem to fit ok, just the brakeline bracket was a bit close, probably need som hammer time.
The brake guy thinks the only problem might be slightly longer brake pedal.
I didn't acually fit up the brakes lines, but I bolted everything in as well as the standard rim. All seems ok.
I shaved the NISSAN logo off because I thought I needed to for another project.
For now im just getting the discs machined and some QFM brake pads.
Heres my pics:
yeah the 4pot Z32 callipers are the same as the R32 GTST 4pots. which is handy because most brake or parts places will have a listing for Z32 4pot pads and rotors.
with regards to the brake line, keep in mind that the S2 stagea callipers are a banjo fitting and the R32/Z32 ones are a flared fitting. you can use the stagea banjo fitting on the R32/Z32 caliper but you have to either, remove the flared section from the calliper, you will see it at the bottom of the brake line threaded hole. or trim the banjo bolt down about 2-3mm from memory, so it does bottom out on the flare fitting.
Series 1 stagea, 9/96-8/98 Dixcel rear rotor available slotted: 325 2018 Same as non type M turbo r32(almost NONE in the country, not the common rotors you will find), and same rear rotor as a non turbo R34(not GT-V, just GT as the V has larger brakes).
Front rotors same as S14 as per first post.
z32 callipers are alloy, r32's are iron, bout a 2 kg weight difference apparently
will the banjo bolt go straight onto the rear gtst calipers after either being shortened a bit or the flared bit removed from inside? Is the top flat enough to get a good seal with the copper washers or should I try and get it milled down ( or whatever it's called) so that there is more of a flat?
Just pull the flare fitting out from the caliper. This is what I did when I fitted my GTST calipers, works perfectly. I have done 20,000kms on mine since upgrading and no problems. Alot of calipers don;t have those flare fittings in them anyway if you look at the standard calipers once you take them off you will see there is no flare fitting inside of them. The flare fitting is just needed for fitting the hardline which normally comes with the R33 calipers.
The RDA954's fit Series 2 AWD Stag calipers without machining down the OD (no rubbing or clearance issues). We have fitted them to one car already and will fit them to my Stag soon.
did the 954S fit your Stag with no issues?
I too am interested; I just tried trial-fitting them to mine without one pad in the caliper (but only with bolts finger-tight - ran out of time) and there seemed to be some binding (though this could have been just friction from the remaining pad) but at least the offset appears correct this time.
Thinking about it I wouldn't expect clearance to be too bad as 6mm diameter = 3mm radius difference, therefore the clearance is only decreased by 3mm and I would've thought there'd be a larger margin than that between the caliper and the disc edge. But then again, maybe it needs to allow for thermal expansion?
As far as I am aware there is no problems with using the standard lines on the rear calipers. I did nothing to mine other than bolting them up and I have had no issues. The only thing you may notice is that the standard rear lines are slightly shorter than what is ideal. Mostly this is due to the different connection point on the GTST calipers. Doesn't seem to cause any problems though. I have attached some old pics I had so you can see what the finished job looks like.
Guy`S Do you READ WHAT IS SAID ON HERE :banana: ,What don`t you get about what i did & have been running on my CAR :laugh: As i SAID BEFORE ON HERE you can run the ROTOR ok bolt it on & go ok ,
if you have to KEEP ASKING :( THE SAME THING REALLY get with it,you have the Photo`s on here & as i have had no Problem`s what is the PROBLEM :wave: ,
i just don`t understand WHY YOU CAN`T follow what i have said & done on this GOOD LUCK .
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
