Tom, I'd guess your bad brake pedal is just more air in the lines somewhere....try more bleeding. I've never had to bleed the abs even when the lines are totally empty....not saying it can't happen just that it never has for me.
Tim, I'm using the A1RM on the rear, they work fine, excellent price but are very dusty. I think I should have chosen HP-X because I don't think I am stressing them enough to need the A1RM
yeah i did the fronts again, few bubbles came out and the pedal is much better now :P
starting to appreciate the increased braking now
Is there an of-the-shelf BMC Stopper available for the S2?
Is there a skyline model that would match?
Edit: Search function is fantastic! R33 for those who need to know :banana:
Edited by d1_drifter
dunno if this has been asked b4 but...
are the stock front rotors r34 gt (non-turbo) ones?
i was asking about gtt rotors in autobarn and they mumbled something about "are they the 292mm ones?"
i should have asked for a part number
but iirc gt brakes use a 2 pot sliding calliper too
DaveB.
How did you go with moding 954 discs and what pads did you find to use?
Missed this somehow - I haven't gotten around to organising to have them machined down again, but the plan is to do that in the next 1-2 weeks when I have some other work I need to finish; then you can be sure that I'll let you know. I think there is also a bendix equivalent pad on here somewhere for around $100 a set thereabouts? Maybe less... I will probably look that up.
hey guys does any one know the bendex number for the frount pads off a 99 RWD stagea, as mine are getting low and i cant find them on here.
There is no Bendix number for the front of the S2 Stagea. We've got them on the shelf as a custom pad, in both HPX (Bendix Ultimate equivalent) and A1RM (Ferodo DS2500 equivalent). Our part numbers and prices for the front are:
GSL009HPX $119
GSL009A1RM $179
Greg.
So are hpx for S2 Stagea on the shelf?? Pm reply put me on back order list?? If pads are on shelf pm payment details please.
Cheers.
Rear are on the shelf mate, fronts are still on back order. I'll put you on the back order list.
A1RM to suit the front and rear are on the shelf if anyone else is interested. $179 per axle set front or rear.
Regards,
Greg
Well boy`s & girl`s iam Happy with my BLACK EBC`S,
I shall try the YELLOW next & see what there like,
It`s a BIG + to just rockup & grab them no BACK order`s here,
Cheer`s Chuckie.
That will be interesting considering RDA don't have any stock of Reds or Yellows to suit S2 fronts anywhere in the country...
And as a premium RDA dealer we also could've sold EBC Black or Greens off the shelf, but the vast majority of people are happy to wait for the [far better] QFM's if they're not urgent for them. Why did the 'back' need to be in capital letters?
Well Sorry to POP your BUBBLE GREG i have some on way,
I have gone for GREEN STUFF,
IN CAP`S ,WHY DO YOU SAY INSTOCK BUT NO ON BACK ORDER AS YOU NEED MORE OLD PAD`S ????,
YOU MAY FEEL there a better PAD but that`s your Product,& from what i have read ROTOR`s will need replacing with one type of PAD as they EAT THEM,
Now AS I DRIVE A STAGEA i guess i have a better VEIW on WHAT IS GOOD ON MY CAR then someone guessing,
YES you sell PAD`S EBC & YOUR OWN PAD THAT YOU COME HERE TO GET SOME STOCK PAD`S SENT TO YOU .
As i had REBOND`S done here in perth as there was a TOTAL LACK OF PAD`S ,& AGAIN went to RDA & GAVE them PAD`S & ASKED for them to FIND A MATCH,SAME with ROTOR`S & THEY come to the PARTY :P:nyaanyaa: ,
As i am not a 20 yearold guy hoping to have someone find stuff for me
Cheer`s
  • 3 weeks later...
Well I had a win today with going to Brakes West In Myaree , They had the rear pads and rotors in stock and are ordering me in some EBC Blacks from over east, get the front rotors skimmed fresh and fingers crossed that should be it for a while !
Ok so the Stagea is all done. New rear rotors * coulda got em machined down but new rear rotors didnt cost that much so I thought meh , might as well *
Front rotors skimmed
New EBC black pads up front
Bendix CT down the back,
Bled all the brakes, took it for a short test drive and everything sounds perfect.
:D
Shame Australian Air express totally f@cked up my shipment of pads and overnight turned out to be like 3 days. but I am happy its all good now
Dixcel Part No.'s for Series 2 Discs WGNC34.
I'd be pretty sure they be straight swap, OD/Offset/Thickness same.
PD-Normal Disc
SD-Slotted Disc
HD-Heat Treated Disc
HS-Heat Treated Slotted Disc
The rrp price is there too converted from yen (currently 76.6)
DIXCEL 98/8~01/12 WGNC34
Front Part No. 321 2013
pd 218.41
sd 327.62
hd 341.16
hs 450.34
Rear Part No. 325 2018
pd 218.41
sd 300.23
hd 354.81
hs 453.99
Edited by Stagea_Neo
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
