God how effing hard is it? Ordered some DB1399's through repco on wednesday said they'd have them thursday but somehow ordered in front pads for the stag... so then ordered them again and DB1144's turn up... Some people can't get anything bloody right.
  • 3 weeks later...
due for front pads for my s2, found bendix now has a listing for them db1696
might be worth adding this to the first post in the thread to make it easier to find
all the c34 and m35 stagea pads can be found on the bendix website here
http://www.bendix.co...an&model=Stagea
I used them in my 180sx and with its weight of only 1250kg, going through the hills it would get severe fade and end up with no brakes at all. They where also dusty as hell.
Put in a set of stock Nissan pads and heaps better compared to bendix ultimates.
i have bendix ultimates. nd i dont get any brake fade through the hills, how ever they do squeal like hell. they are very dusty. only thing i would recommend doing is putting dot 5 brake fluid in if u have dot 4 atm. however i do also have R34 brakes all round. but shouldn't be much difference interms of brake fade.
Well i have DOT 3 in at the moment and is says on the fluid reservoir to use DOT 3 only. I just put some Bendix General CT pads on the front to replace the (worn) stock nissan pads and noticed an immediate improvement in braking performance. They were cheap enough that I can replace them if they fail my expectations but I guess time will tell :thanks:
dot 4 exceeds the requirements for dot3
I've got the remsa pads on the front of mine (with r34 4 pots front and 2 pot rears)a they are lovely, really notice the difference coming from the r31
Dot 5 brake fluid should not be used on an abs equipped road car. It is silcone based and quite different from normal brake fluid.
Dot 3 is pretty much obsolete and can be replaced by Dot 4 or Dot 5.1 (as opposed to Dot 5).
yea sorry meant DOT 5.1, not DOT 5
That is really retarded. Why wouldn't they give DOT5 a completely different name, instead of having DOT5, which you can't use, and DOT5.1, which you should use? So easy to get confused...
:domokun:
Heya guys.. had a half decent read through the thread here but just need confirmation on a cpl things.
I have a s1 stagea with totally crap stock breaks. been offered some r33 gtst 4pots and slotted rotors for cheap.
1.they do bolt straight up.. Ie no need to drill the caliper mounts out larger/sleeve them?
2.stock brake master cylinder is up to the task of operating these 4 pots?
Edit. found the answers i was looking for other than one more question.
Will 33 brakes foul on my standard stagea wheels?
Edited by driftrx
Most sets of 350Z brembos seemed to be around the $600-800 mark when I was looking. Check out Japan then compare to here and the states.
Personally I'd be going the Akebonos if anything. SO sex, and by the time you add up cost of lines, rotors, etc, it doesn't work out too expensive.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
