There is also ones made by HEL which are a bit cheaper than the nismo ones - http://www.ebay.com.au/itm/HEL-brake-lines-Nissan-Skyline-R34-GT-T-GTT-/251232676024?pt=AU_Car_Parts_Accessories&hash=item3a7ea268b8&_uhb=1#ht_1919wt_980
But still unsure as to which ones i require
Ah, i just PM'd you! lol
So if i buy these GKtech ones - http://www.gktech.com/index.php/s14-s15-r32-r33-braided-brake-lines-front-rear-set-intro-price.html
They should fit straight up for the setup i will have? is this what you used pipster11??
Nick
Here are some pics of how I removed the restrictor out of the r34 gtt rear
Calipers. Simply self tapped a screw into it with a screw driver and pulled it out.
Took me 10 secs max for each caliper. Be careful when you trim the bango bolts
Down though! It's hard to get them back into the caliper male sure you file them back
So you don't strip the thread on the inside of the new calipers!
Easy was I found was to use the old calipers to test each time I filed more off
to see if it went in nice!
Okay, possibly stupid question (mostly because it's probably been answered somewhere in here, but I CBF looking through 70-odd pages): I want to replace the front calipers on my s1 C34, and I know I need the sleeves to reduce the bolt holes from 14mm down to 12mm, but what should the sleeves be made from and/or where should I get them? I've already got a set of R32 GT-R Sumitumo front calipers sitting here waiting for me...
Also, can I upsize the diameter of the rotors, seeing as I'll probably replace them with slotted ones anyway (front and rear)? If so, by how much?
Hiya Nick,
Scotty can turn you up some sleeves made from Stainless. I've got them on the M35 to run the GTR setup. Shoot him a PM. Mine are fine - been on the track.
You can go to a Brembo spec GTR disc with caliper adaptors. I know UAS make some, but they are freakin expensive for what they are- like $400. For comparison, I got my GKTech ones for the RPS13 to suit GTR discs for $99. Pity they dont fit, only the 280mm disc. I don't know of any other caliper spacer off the top of my head.
Finally got around to doing this conversion today, and i must say definatley worth it! stops so much better now!
Went together fairly easy, only had to trim the rear backing plate due to it hitting the caliper, but no disc interference front or rear.
I went with R34 GT-T setup, ended up using R33 GTR front brake lines, and GKTECH braided rears, fronts fitted perfectly, rears needed slight tweaking from the chassis hard line connector to braided line, and id like to secure it a bit better than what it is so i may need to have a closer look as to how the rears are supported in a R33/R34.
Used Brand New RDA slotted rotors to suit R34 GT-T and TRW pads all round, and the stopping power it awesome now! :)
Definatley worth the effort for this upgrade! :)
Is yours an s1 or s2, Nick?
Alex, I'll have to check if the caliper bolts are 12mm, like you mentioned they *might* be on Saturday. If so, that would make it easier, and if not then ill get some sleeves from Scott. And UAS are around the corner from me - literally across the other side of the field at the end of my street, actually - but they can be majorly expensive!
Guys, do the late model 3.5L M35 brakes rotors fit the earlier model M35 2.5LTs? I have a horrible brake squeal coming from front right, so going to get new rotors and pads.
Cheers,
Shaz
Unless the rotors are near their limit; why not just get them skimmed?
Chaps,
Does anyone have Part Numbers for Rotors and Pads for my car? I've been having a look for some on the DBA website, specifically at the 350Z, but alot of them are coming up as Brembo Fitted models, which mine isn't.
I'm really just after a set of cross drilled and/or slotted rotors and new pads, standard replacement. I may look at doing an upgrade in the future, but I really just need a straight swap item for the time being so I can bang the job out tomorrow.
So far, the closest I've gotten is DB4600, which I believe are a 324mm rotor. 4000 series heavy duty.
Cheers,
Shaz
Edited by XS80ST
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
