Im hoping to install air temp sensors in the exhaust housing of turbo and intake plenum so i can get before and after air temp readings, have a company wanting to do ceramic coatings inside and out and as many of my engine bay parts as possible, they even wanted to take the sump off and do more coatings in there...
They are hoping to show coating benefits to customers in the real world, so temps all taken at track before and after
I ended up going a Perrin beanie, racers use them for a reason. I Also went and sourced a roll of INDUSTRIAL heat wrap and a couple of sheets of the ACL heat shielding. I've reduced temps massively doing this
  • Like 1
Reducing engine bay temps is one thing also taking advantage of the lower temps effects on the intake charge is another... So reducing outward temp of parts and then reducing heat that can heat soak others
The guys at GCG reckon the Borg warner Beenies are good for 800 Celsius which is fine for the street but may reach higher temps after some hard circuit work. Sprints and a few laps shouldn't see that temp I imagine.
Full-race also got back to me and they do ceramic coat and/or wrap their manifolds and they still give warranty against cracking. Not that I see why it should. Also noticed they ceramic coat their manifolds for 150ish bucks.
Should have had it done when I bought it as GCG quoted me $905 to coat my manifold, turbine housing and 1.5m of dump pipe.. seems steep
Whats the general thoughts on Turbo Beenie vs ceramic coated turbine housing in terms of reducing heat. I would imagine the beanie would work better
I wouldn't use a beanie if your car is used on a circuit, it will heat fatigue your housing. I don't think your turbo has a stainless housing but if its iron like 99% of housings it could be 1 year, could be 10 but it will fatigue crack and possibly warp if your doing regular circuit work. Drags and street is fine though.
Of course you can touch a beanie afterwards, they are 1'' thick! What cracks them is the surface temp/core temp differs and fatigues over time
Best bet is to make your own from ACL and rivet it together. Depending on how well you make it, it will be just as good without any risk. If you only spend 20 mins making it, you may as well make a heat shield out of cheaper mats
Competition coatings in Guilford will be 1/3rd the price on gcg, hi octane coatings etc.
Mine is a Taiwanese stainless Tial copy, still going fine after 4 years wrapped in a beanie. They are a lot thinner than a cast iron housing.
I doubt either will crack or warp just from the beanie, perhaps if the exhaust is hanging off it with no flex joint like most of you run your systems.
I'll give the guys at comp coatings a call then.
Someone previously posted that they wrapped their Intercooler piping.
I'm not sure what the purpose of this is for. Yes you may stop some heat soak but wouldn't it be better to keep the piping exposed to the air to reduce charge temps as appose to keeping the heat in
Turbo makes the air hot. Intercooler makes the air cold. The hope should be that the air coming from the cooler into the engine bay would be colder than the engine bay environment. Ergo, wrapping IS about keeping the heat out. This is especially true when stopped or crawling in traffic. There's no heat in the incoming air - so stopping it from getting hot between the front of the car and the plenum is a good thing. Allows you to make power without pinging if you suddenly want/need/get to put your foot down.
If the air returning from the cooler is hotter than the engine bay, then it is not going to lose much heat to the engine bay anyway. This would possibly be the case when you're on high boost and load and the intercooler is only able to get the air down to a still fairly high temperature. In this case, the wrapping may stop the charge air from losing a little more heat to the engine bay, but the engine bay is a pretty hot spot, so you can't imagine that the loss of cooling power from wrapping it would be worth worrying about.
FWIW, I have my return pipe wrapped in glass wrap and then reflective foil+bitumen tape as well. The latter because it is easier to wipe clean without glass fibres coming loose all over the place, pain of working with your arms rubbing up against glass tape, etc etc.
Edited by GTSBoy
I agree. It was good enough for Gibson. :P
Thanks for the post GTS boy
im thinking I will use a black wrap on the greddy hard pipe kit I have so it doesn't look sho shiny and gay.. stands out less on the pipes coming off the cooler in the front
where did you purchase your reflective foil and bitumen tape??
interesting what looks like support bars for the turbo/manifolds, certainly can be a heavy load hanging off the manifolds on modded cars. Is that to stop the manifold
cracking under hot racing conditions?
Edited by AngryRB
The cast manifolds turn to jelly at 1000+C, yes the bars are there to support the weight and keep the manifolds in one piece, seems to do the trick...
I needed aluminium tape and seen that tape in bunnings. Not sure if its the right stuff. I ended up getting aluminium tape from Jaycar for $11 rated to 120 deg c. It looks more like the tape used on the Gibson car.
Bunnings starts at like $26
I doubt either would do much on a greddy hard pipe kit, its already polished alloy
If you don't like the look just paint it with 2k or engine enamel (something that wont scratch easy) or ceramic coat it. Wrapping a hard pipe kit will add Zero gains. One hit on boost with 100deg + outlet temps from the turbo and it will be just as hot as anything else.
Have a close look at the Gibson picture, they "over trimmed" the manifold heat shields. They could have had warping issues due to temp so they were trying the "more airflow" approach then that caused a heat soak issue in pit stops.
TLDR Hot side don't worry about it or just paint/coat it for looks/preference. Cold side do what you can to stop heat soak only if you have long cross over pipes (rb20/25). RB26 is too short to bother with
Yuh, and on RB26 the return is on the driver's side of the bay. Stock pipe layout on 20/25 passes the return over the turbo, so worth doing what you can there I suspect.
  • 4 months later...
small revival,
whats peoples opinions on ceramic coating the external waste gate pipes?
I would assume there would be a small advantage in terms of keeping engine bay temps down, performance wise i'm guessing the gains would be minimal.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
