probably cause it is cheaper and suits Christian more, you know to buy software for and host a forum isnt free and you dont pay for it........SO STOP WHINGING. Not being harsh just fair!!!
why does it say RB25DE under my avater ???
how do i change it?
its hard to find my way around,i gotta change colours
In your control panels under your profile - the first part custom name or something.
The new board doesn't look as nice as the old and I prefer the old layout but Prank has outlined his reasons on another post and they sound solid. Either way the usebase is here and that's what counts.. as long as we keep all the smilies :)
There are several threads in the wasteland on this..
Its heaps better, it just needs tweaking, which the mods are doing now..
They put fast reply back in, thats a good thing, Im happy
The rb25de thing is your rating on how may posts you have. when you have more that 500 (rb25det) you can change it.
Change it to the IPB default skin if you want the text to be bigger.
thank jebus..
so much better.
I suggest everyone try this skin...
although it kinda reminds me of nissansilvia.com but it's easier on the eyes..
and it's white instead of blue.
once the features of the vb forum is returned, (quick reply, smilies etc etc) this one should be quicker, and apparently with much more add ons.
I am getting used to it, and would like to congratulate the mods for doing this; a fresh, welcome upgrade
Yes i agree, The default skin is much better.
Sorry for being uneductaed in these sort of things but how do I use this default skin you guys speak of to make the text bigger? Because I am also having eye straining issues.
Thanks
EDIT~~ Found it. Thanks for the tip it is much easier on the eyes.
ok, to type this out for the hundredth time...
There were LOTS of behind the scenes problems with VB that were causing issues and creating excess work, upgrading didnt fix it and the vbulletin guys are still looking up what 'support' means in their dictionairy. IPB isnt cheaper, its more expensive and the new forums + blog feature cost Me $USD 245 (about $320 AUD) so I can assure you that it was done for good reason and not because I wanted a change or for any other personal reasons. IPB will be much faster and better overall and once everything is installed and running well you'll see that too.
Hope that helps people understand
Christian
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
