The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Just copy and fill in the table;
Skyline model =
Wheel diameter =
Wheel width =
Wheel offset =
Tyre size =
Modifications to fit =
One of mine as an example;
Skyline model = R32GTST
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 35
Tyre size = 245/45/17
Modifications to fit = remove the front inner plastic guards, roll rear lip slightly.
:( cheers :)
Edited by Sydneykid
  • Like 1
https://www.sau.com.au/forums/topic/84208-wheel-sizes-offsets-for-skylines/
Skyline model = R32 GTSt
Wheel width = 8"
Wheel offset = 32
Tyre size = 235/45
Modifications to fit = Roll lip
Wheel width = 9"
Wheel offset = 37
Tyre size = 255/40
Good work Sydneykid, now let's see all the R32 GT-R people posting!
Skyline model = R32 GT-R
Wheel diameter = 18 Inch
Wheel width = 9 Inch
Wheel offset = +24mm
Tyre size = 265/35/18
Modifications to fit = None
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +1mm ;)
Tyre size = cant remember probably 245 or 255
Modifications to fit = Roll & flare guards, stick out about 4cm from existing guards. needs a rear bar for them to look good... not good for defects..... almost needs widebody...
http://i2.photobucket.com/albums/y19/merli...12/IM000091.jpg
http://i2.photobucket.com/albums/y19/merli...12/IM000070.jpg
Wheel width = 10"
Wheel offset = +1mm  :)
Whoa dude.... ;)
Wheel width = 10"
Wheel offset = +1mm  :P
haha the rear looks like a AE86 drifter
Any idea how much clearance you have to the strut and also does it touch the inner guard lining on full lock?
Mine -
Skyline model = R33 GTS T
Wheel width = 8.5" front / 9.5" rears
Wheel offset = +30 front / +38 rears
Tyre size = 225/35R18 front / 255/30R18 rears
Modifications to fit = None. Car is on slightly lowered springs, very rarely will touch inner plastic guard when at full lock and hittin a pot hole at the same time <_< .
Edited by thommo
I think i've posted this link about 100 times or so in this section. But it's a very useful link.
http://marksink.com/tire_wheel_offset/offset.html
Use this to enter the offset and width of you current wheels, then input offsets of wheels you will like to buy and it'll tell you how far it'll stick out compared to your old rims, and how much clearance you'll have with the strut housing.
(maybe sk you should add this to the top post)
Skyline Model = BNR34 R34 GTR, BCNR33 R33 GTR
Wheel diameter = 18
Wheel width = 9.5JJ
Wheel offset = +12
Tyre size = 265
Modifications to fit = none
Wheel diameter = 18
Wheel width = 10JJ
Wheel offset = +20
Tyre size = 265+
Thanks for the link, the idea of the thread was to get the guys posting up their actual real world exeperiences all in one place. I don't know about anyone else but I have real problems with using calculated changes (one rim to another) to know whether or not the wheels will actually fit. An example, so it's 5mm in further, does that mean it will hit on the inner guard or not? Then there is the brake calliper clearance issues.
Thats why I wanted to have a whole heap of real world results for guys to look up.
:P cheers :)
Edited by Sydneykid
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
