anyone have pics or have fitted 18 x 9 +30 with a 235/40 on the front of a 32 gtst?
i got mine on atm, adn its mm's from touching the uca, but i just would like to see how low people have gona with at the front
i am running coilovers so i can adjust, but cant drive car as engine pieces getting powdercoated
Nick
i'm looking at getting some meisters for my r33
looking at
19x8.5 or 9 at the front
19x9.5 or 10 at the back
what kind of offset is required? it wont be slammed i want to roll the lip on the guard
heres how it rides atm wit 18s 265s on the rear and 235s on the front no idea on offset of rims
okok thanks for that if those offsets are for sitting flush with the guards i mite go a bit lower in offset so its sticks out like 5mm
so something like 19x8.5 +25 and 19x9.5+30 and hopefulli i wont hit the guards when i put the dampers on the hardest setting
the issue is 19's arent great for fitment because u cant gain as much clearance by stretching tyres
from another thread in this section:
fitting a 9.5 +22 with a 225/45 tyre would actually be pretty easy, my main concern is being a 19" wheel, even though it will be the same amount of stretch, the angle will be sharper, like so:
the blue is a smaller wheel with a larger profile, and the red is a larger wheel with smaller profile but same size tread. the green is at sitting height, the yellow is on compression, the angle change in the 2 guards is due to dynamic camber, obviously in real life its the wheel/tyres angle that changes, but its easier to just show the guard changing angle.
as u can see the lesser angle of the sidewall on the tyre on the smaller wheel allows the guard to come down further, even though the offset, rims width and tread width are all the same. hence why its really hard to get agressive fitment on higher diametre wheels.
so its hard to really get the fitment right with them. with the specs i gave u, depending on the camber they will probably just stick out of the guard a few mm at the rear.
Hey everyone. First time posting here I believe. PM'd a few guys about things, but that's it.
Anyway, I have a set of TE37's I was planning on putting on my widebody Sileighty (S13.5), but since decided to go another route.
I currently have a '93 R33 GTS-T Type M coming across the Pacific and was wondering how well my wheels would fit.
In the front I have 17x9 +0 and in the rear, 17x9.5 +12.
I have no clue about Skyline offsets and to be honest, did not want to take the time to go through so many pages.
If someone could help me out, that would be super!
They will stick out the guards by heaps. About +25 to +40 is ok for a 33 GTSt.
Are you from the states?
u can make them fit, but u will need guard work, silvias usually have more clearance in the rear guards, the fronts are similar how ever.
heres a few pics, R33's have a bit more clearance than the R32's.
17x9.5 +13, 235/45 30-40mm flare (mock up with unfinished guard)
17x9 -1, 215/45, 30-40mm flare
17x9 +16, 225/45, rolled guards
Ive been reading through but just getting mixed answers
I have a 96 r33 gtst series 2. Currently has 17" work's not sure of the offset.
However i dont want to do any gaurd rolling or flaring (dont want to damage the paint) so im assuming i couldnt get anything over an 18"
What size, width and offset would you recomend for stock gaurds?
THANKS :D
width and offset play just as big if not bigger roles in clearance than diametre. u can make a 20" fit if u want, u just cant go as wide or have as low offset as a 17".
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
