18x10 +30 (235/40) on rear or 34, clears coilover and standard guards, will need to roll if going 255 + tyre size.
should be able to fit +10 to +15 offset with rolled guards (will try when i get some spacer action happening) - pics up soon after i fit them up.
+1 to CE28N, very nice wheels :P
Skyline model = R32 GTS-t
Wheel diameter = 17
Wheel width =8F, 9R
Wheel offset = +25F, +35R
Tyre size =215F, 225R
Modifications to fit = No spacers required, they sit flush as on the front, rears come out about 4mm, stock suspension and guards.
tried my mates work vs 18x9+4,18x10+9s on today,sat mint as car looked so tough
Skyline model = r32 gtst
wheel diameter =18"
wheel width = 9f,10r
wheel offset = +4front,+9 rear
tyre size = 225 f,235 r
mods to fit- massaged the guards a bit
currently running work equips
wheel diameter = 17"
wheel size = 8f,9r
wheel offsets = +5f,+15r
tyre size = 205/45f, 235/45 rear
pics of both when I get to a computer
so im gonna need a bit of help fitting these bad boys.
wheel diameter = 18'' rear and 17'' front
wheel width = 9'' all round
wheel offset = +6 rear and +/-0 front
tyre size = 225 rear and 205 front
got a few crappy fone pics....
rear im hoping to get way with some neg camber.
front ill prob need to flare and run some neg camber (front is going to get dropped a bit more as well lol)
yeh 215 on the rear, or 205 if ur not too fussed about traction back there, then as much camber as u need to slide it under. u obviously dont want too much if ur still after traction, massaging the guards just a little bit might be a better solution.
for the front just camber the f**k out of it, R33 LCA's will help, but they tend to push the bottom out more than pull the top in to give u camber. for maximum clearance from camber ur better off with some adjustable upper arms and shorten them, something around -3.5 should do it id imagine, but just keep going til it fits in. front guards are easy as piss to pull out a bit if u need a bit more clearance.
Nisskid, how would I go about bringing the top of my rear wheels (17x9+35) in a bit? They currently stick out about 4mm when looking down at them on stock suspension and guards. Ive been told more than one way and I'm confused haha
Skyline model = CPV35
Wheel diameter = 20"
Wheel width = 9.5F & 10.5R
Wheel offset = ET22
Tyre size = 255/30/20F & 285/30/20R
Modifications to fit = slight roll of rear guard
is it a scrubbing issue? also what size tyre.
there is really only one way to "pull" a tyre in, and that's to add camber. unfortunately at the rear once uve lowered ur 32 even a little bit the dynamic camber gives u way too much camber on the rear for the street, so adding more camber will just make ur car perform even worse. if there are scrubbage issues, roll ur guards (assuming u havnt already as 9" +35 shouldnt be scrubbing, unless ur running maybe a 255/45).
Stretched 225/45/17 (Came with rims). No scrubbing issue, I'd just like to tuck the top in a little extra - so bring in the top of the tyre 2-4mm. I do plan on lowering about 25mm, will this get me that little bit more camber? Also guards are not rolled.
Thanks for your help :domokun:
So I've posted in this thread in the Motorsport section of the forum but didn't quite get a full answer.
I'll keep it short, went looking for rims, couldn't find what I liked second hand, so found Enkei RPF1's for <$1700 delivered brand new, they're lightweight which was my main thing.
These rims are going to be track only rims for an R33 GTR, it currently runs stock GTR 17x9+30 rims.
The plan is to keep it 17inch, I have choices of:
17x9+35 (or +18)
17x9.5+18 (or +38)
17x10+18
From the wheel offset calculator its:
17x9.5 is 6mm more inner clearance and 18mm extra sticking out
17x10 is 1mm less inner clearance and 25mm extra sticking out
The plan was to not have to re-tune suspension after switching, and the 255/40/17 tyres are cheaper than 265/40/17 which says 9.5" from my point of view.
Any advice?
P.S. Nisskid, excellent guide on rims, I tried reporting that your links to the wheel offset calculator are broken but no response, they now need to be "tire" instead of "tyre".
Thanks for your help :)
lowering will give u extra dynamic camber, so as u lower ur car the top of the tyre does tuck in a bit. hence why when ur car is off the ground, the tyre sits right out of the guard, then when u drop the car back down it settles in.
17x9+35 (or +18)
17x9.5+18 (or +38)
17x10+18
Any advice?
17x10 +18 would be my pick for a R33 GTR. 9" +35 is too thin and offset is too high, +18 is a bit better than standard, but if u were going to have a 17x9 id stick with stock R33 GTR rims as they are better quality than the enkeis. 17x9.5 +38 is too high offset, +18 would work, but honestly if i was going to spend the $$ id do it right first time and go 10" wide. gives u more options.
can anyone foresee any troubles with 17x8.5 +32 (F) & 17x9.5 +28 ® going onto a R33 gtst with stock suspension. not really after the stretch look on tyres (not my thing) as it will be for street use only, no track work at all
I will be upgrading the suspenion at a later stage (possibly something like the HSD twin tube coilovers)
will be fine
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
