^^^ Nope, it'll stick out heaps.
If you want flush go for +25 and a bit of guard work, or +30 if you're not that crash hot on playing with the guards.
should look the goods but why not go staggered? smaller width front to rear?
yeh roll you guards tyres wont need much stretch if any
Coz there is absolutely no need to for any reason.
The site I'm buying from only have the Work Emortion 11R 18's in the one fitment, unless i want to drop to a 17 and that would look to small on a R34.
I also have a brand new set of bronze Work XT7s in 18x9.5 +12 all round that are for sale. $2k for the set.
you sure? saying that makes me wonder if you know what your talking about there is benefit to staggering just depends what you want to achieve.
Staggered wheels are to run more side wall and to achieve additional clearance in the aim of more lock.
This is an issue that is far more relevant to S series chassis' than R series (due to R's have more guard clearance).
Therefore, there really isn't any need to go staggered at all.
LOL at me not knowing what I'm talking about :D
  • 3 weeks later...
hey guys just a quick question
i just brought some 18x8.5 +30 all round on my r32 gtst
wondering if i should put 235/40/18 tyres all round or 235/40 front and 245/40/18 or 255/35/18 rear.
i have read through most of the pages but im little unclear still
Also will Work Emortion 11R 18x9.5 +12 all round sit flush on a R34 25GT guards ?
Thanks again.
Dude that will stick out heapssss on a r34!!! +20-30 and you'll be pretty much perfect with camber and guard work!
Just copy and fill in the table;
Skyline model = R32 GTSt
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +1mm ;)
Tyre size = cant remember probably 245 or 255
Modifications to fit = Roll & flare guards, stick out about 4cm from existing guards. needs a rear bar for them to look good... not good for defects..... almost needs widebody...
http://i2.photobucket.com/albums/y19/merli...12/IM000091.jpg
http://i2.photobucket.com/albums/y19/merli...12/IM000070.jpg
haha damn thats keen.
First thing i thought when i saw that .. was crazy arabs with 22"s and so much camber steering components are touching the ground!
NM35 Stagea 2002
Autogaurd jap tyres
17 x 45 x 235 stock
came stock no modifications
thinking of going straight to 19's with 245s all round.. looking to go straight on!
Edited by PetroDola
thats massive post pics when done dont think its going to be easy ..
I dont know whether or not ill stick with the norm and get a safe sized set of tyres since i havent heard/seen of any 34gtr's with this done, however i have seen 33gtr with similar set-ups and i hear that the 34gtr wheel well is slightly larger.
Being a size 18x11, i feel compelled to try something slightly larger.
That being said, anyone with pics or experience in whether or not 295's+ would fit ?
Cheers
Dave
Skyline model = R33 GTSt
Wheel diameter = 18
Wheel width =
Wheel offset =
Tyre size = 235/40/R18 91W
Modifications to fit = nothing...
Edited by Drift88king
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
