hey guys lookin at gettin a set of lenso d1rs for my r33 gtst
dont want to do anything over the top so no camber etc, will roll guards if needed and remove plastic liners
just want them sitting nice and flush with the guards...also car wont be lowerd too much as it has a kit so guards will sit about a cm or so above the wheel
heres some specs from the lenso website
WHEEL SIZE: 18x9.0®
ET: +15,+32,+40,+44
PCD: (5x100~114.3)
WHEEL SIZE: 18x9.5®
ET: +30,+40
PCD: (5x100~114.3)
WHEEL SIZE: 18x10
ET: +15,+22,+29,+36,+41
PCD: (5x100~114.3)
i hear the 18x9 +32 sit flush at front so ill probs be goin with that for the front,
question is from above what size will sit flush with the rear keeping in mind i dont want to run camber etc
how is that stupid? that is correct... 9mm more
imho go the 9.5+30 for the rears as it will look the same as your fronts.
9.5 + 30 is flush with no camber... i ran it for a couple of years
thx for the help guys
looks like id go
front 18x9+32
rear 18x9.5+30
with this flush fitmet ill need to get guards rolled n remove platic liners, i can remove platic liners myself, but who/where will do a good job of rolling the guards at a reasonable price?
how low do you wanna go?
fronts will only need the liner taken out if you slam it
180athid is te man fr al your guard rolling needs
cars got a kit on it, so wont be slamed for legal reasons, but wheel arch will sit above the tyre 10mm minimum may be more though.
180athid do i just pm him on sau...does he work at a shop or does he just have the equipment to do it afterhours?
hey man yeh leave your liners for now i doubt you'll need to roll them. Also id get ya wheels fitted up theres a good chance you wont need to roll em on those specs depending on ya height so save some cash for now can always do it later (roll the guards)
just so you know 10+36 will sit the same as 9.5 + 30 for outer position, if your wanting that fat look from behind id be heading down the 10" path. hope it helps :thumbsup:
Hey guys, really needing some help if someone out there is smart enough, I've tried researching and trying to learn but it all gets me confused =S
Anywho, long story short I'm currently building an R33 GTS-T RB25/30 with a custom wide body that i'm making myself lookin pretty sweet fiberglass btw, scissor doors etc, all metal fenders etc retained.
So the front body is 1 1/2" wider than original body, looking for wheel to sit out 1" past the original body.
and the rear body is 2" wider than original body, looking for wheel to sit 1 1/2" past the original body.
I have no problem at all rolling the front guards to fit, whatever it takes
I have no problem cutting and welding the rear arches to fit wide wheels past original arch (I'm a welder by trade)
Also after a decent dish! at the moment the car has 17" Sparco Racing rims can't remember width and offset.
wheels also have to get around the brakes without spacers / adapters
if you understand this and what I'm after, please help, I'm happy to take measurements, answer questions, etc.
Any help or advice greatly appreciated, just wanting to know if anyone has any idea what sizes and offsets i'd be looking for when searching for my wheels =)
easy man, you want to run camber ? guessing maybe not if its a widebody fibreglass scissor door autosalon style car by the sound of it?
if not just run a 9.5 +15 front or a 10+20 at a guess rear go an 10.5 or 11" with a 15 to 25 offset should do the trick.
but i have seen a widecustom 33 and the fibreglass returned inside too far to run wide wheels so hard to say without seeing what your working with.
actually just did a quick check for you.
if 9+30 is fairly flush on stock guards a 10" +10 will be 1.102 inch further out.
rears if you run an 11 +15 will sit 1.33 inch further out than a 9.5 + 30 which again is fairy flush on stock guards. None of this is taking into account stretch/camber/ride hieght but i doubt its overly relevant.
thanks mate, ill probs just stick to the 9.5+30 on the rear, long as its flush with the guards thats all i care about, cos i didnt really like how my rims on the na sat inside the guard
also with these specs front: 9+32 rear 9.5+30 what size tyres should i get?
Buckled a rim on the weekend...f*** you Wellington Road.
Long story short, I have D1R 18x9+32 all round...fronts looks reasonably flush but I always felt the rears could come out wider. Was going to put on spacers, but now that I need a new wheel, I'm seizing opportunity to buy two new wheels in a more suitable width/offset. Car is an R33 GTS-T with guards rolled but no flare. I'm not a fan of negative camber, but I want these new wheels as close to the rear guards without scraping.
What am I looking at offset boys? Wouldn't mind a 10" if I could pull it off (insert masturbation joke here) with the correct offset, but will this cut it fine with the suspension gear on the inside? Safest option seems to be 18x9.5+30 like Jason is getting, but will the extra 1/2 inch make much difference or will I be back where I was before?
Good idea on the offset calculator for inner clearance...
http://www.1010tires.com/WheelOffsetCalculator.asp
Outer guard clearance is alot harder to measure though, particularly as it's an aesthetic thing too. Just wondering from experience what people have seen on the rears with rolled guards and no flare.
i have the 17x10 +15 on the rears, but i have slightly stretched rubber, and a bit of camber to make them fit. like you said, your not keen on camber so i think the only other offset they come (in NZ anyway) is +35, so i guess they are your only option in the 10" rim???
Got the XD9's on my car now, fronts are 18x9 +20 rears are 18x10 +18 (thanks to alr33x and joeyjoejoejuniorshabadoo's recommendations!). Rear guards were pretty stuffed though from apparent (poorly done) old crash repairs on the right rear so the paint is all majorly cracked around the guard from being rolled pinch.gif next stop paint shop/panel beater it seems, probably need to flare the rears a bit anyway.... Anyway here they are in glorious shoddy camera phone form whistling.gif
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
