Hi guys, thinking of getting some wheels for my r33 gtst off one of the traders. Been reading the thread but still wanted opinions from some of the more experienced members. I was looking at getting the following specs:
18 x 9 +15 for the fronts
18 x10 +15 for the rears
Looking at running 235s for the front and possibly anything above 235s for the rear. I will be purchasing camber arms and rolling/ flaring my guards as necessary. My questions are:
- how agressive is this fitment? I want to achieve the wide stance without overly sacrificing the life of my tyres. I do understand that camber will come into play, but I would like to avoid having to change my tyres every month just to achieve a particular look
- would 235s at the rear be sacrificing traction? If so, what would be a better recommendation? As I said I'm willing to roll/flare and purchase camber arms, so what combination would be best for the rear
Oh and I forgot to mention that I will be purchasing some coilovers also, but won't be lowering the car to a ridiculous height since I have a driveway I have to get in and out of. Any advice would be greatly appreciated.
id be keen to see the results of that combo, thats an inch wider than mine on the back, i dont think you want too much more camber on the back, its got enough already
it would be awesome round a track though.
Mate do you have any pictures of how your car sits? I'd like to have a visual just so I have a benchmark to compare against. And what did you mean about the camber in the back?
Just took the plunge and bought myself some Ame Circlar Spec R in 18x9 +15 and 18x10 +15 from one of the traders (Autotechnik). I'll post up some pics when all the work is done. Probably in a couple of months. :)
you'll need alot of camber in the rear, and the front on stock guards will fit with a roll but will have to stretch
tyre life wont be good at all.
should have pics of my 9.5+13 and 10+9 end of next week.
Awesome, looking forward to the pics. Also I spoke to PhilB (from this site and JDMST forums) and he said that he ran similar specs and for the rear, with a bit of rolling and a flare/pull he was able to minimise the amount of camber that had to be run. So fingers crossed I suppose. And luckily for me the skyline isn't a daily driver so hopefully that will minimise tyre wear. :)
My car for example. Previous wheel: (f) 17x9.5 +0 and ® 18x10.5 +15 lots of camber on the front, something like -4 and stretched tyres all round
Awesome, thanks for the photo blags. Car looks awesome!
pretty sure 10+15 will need fair bit of camber if you are only rolling, my camber arms are on full for the 10+20
So alex, your guards were just rolled? I'll be getting mine pulled and/or flared at the rear so hopefully this will allow me to run less camber. So what is the maximum camber setting at the rear for an r33 (in degrees)?
Anyone fitted 18 x 10 + 15 on there 32 gtr? any photos? modifications required?
was thinking of putting 255's or do you guys reckon definately 265's.
Cheers,
Thanks
did u end up fitting the 18x10 +15 rims, got pics or comments on the fit?
Thanks for input earlier guys, ended up getting the 18x10's with +22
So next question i have is tyres
Obviously there are so many to choose from but ones i'm looking at are Toyo's flagship T1 Sport tyres
Sizes i was considering were either 265/35, 275/35 or 285/35
I'm kinda leaning towards 275 at moment
Anyone know if i'll have any clearance problems if i choose the 275 or 285 options?
any updates? pics?
im looking at 18x10 +15 on R32 R
I'm running 18x10.5 +15 TE37s on an R32 GTR with 265/35R18 semi slicks on them and I had to get the guards rolled slightly and the rear raised a tad.
They stick out a little but look f**king awesome IMO.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
