Hey guys would a set of 18"s 9.5 and +26 with 255/35 tyres all round fit fine without any issues on a four door r33gtst stock height?
Edited by BrOwnY GT
Hey guys need some advice been looking through this topic ALL night and still unsure of what to get. Ok I have an r33 gtst wanting 18 by 9 or 19 by 8.5 in the front and 18 or 19 by 10 in the rear. I want to run at least 265 40 tires in rear and 235 or 245 40 tires up front. Really want this height cause the roads here a kinda bad, willing to drop to a 35 in height but that is the absolute lowest I can go. Now I was wondering what offset I would need for the front and rears to make the wheels fit with as little modification as possible? I can adjust height and roll guards if I have to, but that is all I really want to do. What offset do I have to run to make these combinations work?
I was thinking an offset in the low 20's would work for the front and low 30's high 20's for the rear?
What do you guys suggest?
Edited by Daboss
this will be a little different from the norm..
Skyline model = R33GTST
Wheel diameter = 18"
Wheel width = 13
Wheel offset = a magic number
Tyre size = either a 275/35/18 or 295/35/18
Modifications to fit = Widebody
AHHHHH!! are they the wheels off ebay that were on there for ages?
i so thought about buying those for my 33 gtst..
I'm rolling on 18x9.5 +12 fronts, 18x10 +15 rears on completely standard metal, no roll or lipping at all, i am running 225/40/18 all around though on teins
post-57781-0-86054700-1327644180_thumb.jpegpost-57781-0-40898800-1327644194_thumb.jpeg
Havent had a good look, but I should be able to fit 18 x9 18 x 10 +22 on a 32 gtst with a little camber and slight roll pretty easy yeah? What tyre sizes would people reccomend? Thinking 215 and 235 in a 40 or 45?
my fronts are 18x9.5+12 with 225/40 r18 tyres ,modifications to ift are rolled guards and remove the inner plastic .
and the rears are 18x10.5+22 with 245/40r18 tyres ,modifications were rolled and flared guards done by a mobile guard roller/flarer
i have about neg2 on the fronts and 0 camber on the rears . hope this helps at all .
^^^ before i got the flare done.
Pics please! You must have some stiff coilovers
Hi there, fairly new to the skyline scene, and not sure if the wheels I've got in mind would fit or be too wide... Any advice you could give me would be appreciated. I've got an N/A R33 which has the 4 stud hubs. I'm gonna be doing a 5 stud conversion soon, and so I'm starting to look at wheels. I've got a set of wheels in mind... They're 18s which are 10in wide all round, with 30 offset. They're coming off an S15, so I'm under the impression that means they should fit my 33 with no problems after the conversion? Correct me if I'm wrong. Thanks guys.
Ah, yeah true.
Anyone got pics of 9.5 +22 on a 33 gtst? Got some Rays in mind, pretty confident they'll fit but wouldn't mind seeing how they sit
they will sit 3mm further out then my professors did....
AWWWWW come on guys no help!!! Help please?????? Open to suggestions. What is the widest tire size I can run in the rear and mods would I need to make these rims fit front and rear? Looking at 18 or 19 by 9 up front and 18 or 19 by 10 in the rear. I dont mind rolling the guard and a bit of camber but if it can be avoided I would like to if not I am willing. Offset for front +36 rears +43
Edited by Daboss
Just copy and fill in the table;
Skyline model = R32 Gtr
Wheel width =10"
Wheel offset =+12
Tyre size =235 40 18
Modifications to fit = none so far.
Car has bc coilovers fitted. Front can go lower which ill do when i get more time. reckon the back may rub with passengers.post-66556-0-47619800-1329052281_thumb.jpgpost-66556-0-01544800-1329053283_thumb.jpg
Ah, yeah true.
I've got 18x9.5 +22's te37's with 265's all round on my gtst, pics in my build thread.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
