also 17x7 +~25 will look aids with any tyre size
Good AIDS or bad AIDS? :D I've got this good looking set thats going cheap ... 17x7 +35 - would love to see if someone has anything similar, went through around 50 pages last night didnt find anything close :P
ok, 25 mm hubcentric ichiba spacers should be on there way soon, Will be on a set of 18x8 +30 offset all around. Will post pics once installed.
Also someone was mentioning to me that with spacers the arms of the car will naturally toe in casueing camber? can anoyne shed light on this?
Or it was lowering the car will naturally casue camber. a little confussed on this
Edited by sydking
I'm going to be running 9.5+22 all round very soon, I'll put up pics when I get them
Cheers looking forward to the pics im planning on getting new rims in a few weeks that size and offset :P ill post up pics when i get them fitted etc... most likely need to roll the guards what tyre size you running do you know yet? was thinking 235/40/18 fronts and 245/40/18 rears
Edited by DarkRyda
can some one plz post a side on pic of 18 x 10 + 20s side on? and aslo 18 x 10 +12 side on? on a 33 GTR plz
And when i say side on i mean so i can see how flush or how far they poke outside of the gaurds.
Yeah 235/40 all round, it's a very common size so much cheaper than 245/40
Hey guys looking to get work meister sp3s 18 x 9.5 offset +16 on a 235/40/18 on s2 r33. Im going to take out the inners and roll the guards and run approx 2deg neg camber all round. Question is will the fit/ anyone got pic of s2 with similar spec wheels
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
