ok another one for you guys, i didn't end up going down the d1r path but i can get some Grid R's in 18x9.5+22 and 18x10+15 tire wise there 225's i think.
Just wanting to know how they will fit, As stated in my last post my car is fairly low & has rolled front & rears, guessing ill need to take out my inners/liners as they scrub now just past half lock. will i need to pump the rears?
cheers
and finding out what your current wheels are would make it really easy with a few measurements.
it should be written somewhere on the back of the rim/spoke of the wheel. Concentrate more on getting the right offset than getting 10" wide wheels
I found out that the 10" that im looking at are +22 offset. My car is standard height atm and has standard guards. You reckon they will fit ?
Skyline model = R32 GTS4
Rim Model = Enkei RPF1's
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +35mm
rim fouls on caliper, i was told these rims would fit and i dont really feel like buying spacers. does anybody know what dimensions will fit a r32 gts4?
Just out of interest, is it necessary to remove the guard/wheel arch liners out if you are running decent size wheel & tyre or lowering a bit?
My car isn't what you would call low at all, but because my suspension isnt race spec coilovers (they're bilstein/whitelines) and they aren't rock hard, I get scuffing when I go over a hard bump or turn real hard up front.
Or do most just sort it out with camber?
Wheel width = 9"
You need a bigger 'X-Factor' i.e caliper clearance this changes from wheel to wheel and is not dependent on wheel width or offset.
For instance I have a set of Evo V Enkeis and a set of Work Meister M1Rs. At 17x7.5 +35 my Enkeis have more brake clearance than my 18x10.5 +15 Meisters due to a different X-factor.
Edited by Hank Scorpio
Skyline model = R34 25GT Sedan S2
Rim Model = TE37's
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +22
Car sits standard at the moment but looking to lower after wheels are on if it is even possible.
Whats the most practical wheel size/type that won't cause any rubbing or require me to do any modification and what is the most plausible that won't cause me any grief such as clearing callipers etc.. i was thinking 235/40
Edited by Bo Bo
Looking at getting some new rims for my r33 gtst, Im not keen on having to get guards rolled or pumped and want to have the wheels sit flush for legality.
I have been told by a few people to look at 18x9.5s all round in offset of about +30 to +38 or f 18x8.5 and r18x9.5 in similar offsets.
Ideally, I'd like a non staggered fitment and to run something like a 235 or 245 with maybe a 40 or 45 profile. However if that causes fitment issues in the front then I'm happy to go 8.5s in the front and obviously a skinnier tyre to suit.
Just wondering who has run wheels in these sizes/offsets/tyre sizes on a 33 gtst?
Any other opinions on the above are appreciated as well
as to legality it depend on what state you are in.
18x8.5+30 and 18x9.5+30 will fit but you'd still wanna roll the rear guards
9.5+30 all round will look better but you will wanna be looking into removing the guard liners if you want it low.
235/40/18 (but if you wanna be legal 245/40)
Skyline model = Laurel C35 Club S (Skyline in a tuxedo :whistling: )
Wheel model = Work Meister S2R
Wheel diameter = 18
Wheel width = Front 9, Rear 10
Wheel offset = +35
Tyre size = Front 245/35, Rear 255/35
Modifications to fit = Rolled gurads, -1.8 camber front, adjustables with spring upgrade (10s&8s) so not toooo much wheel travel
Thanks for the advice, what if I went 9.5 +38 all round with a 245/40?
From what I can tell the rears will sit pretty much flush with the guards so perhaps the only concern will be the fronts ?
What up sau
Im about to get a set of xxr 527's which are 18 x 8.75 +20 all round and my question is will the rear rims be a bit small for the rears or will it be ok, planning on running 235/40 all round ,
any suggestions please cause im planning on getting these tomorow
Edited by 33VOM
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
