Hi Everyone looking for purchase a set of Gramslight 57D for my GTT. I had read a bit of the old post here, some say they can run +20 to 22 all round without any problem, But most people do +35 to +30 offset. I have no idea which will be the best offset for the GTT. Current with HKS hyper Max 2 coilover with 1 and half finger gap all round and RPF1 18 x 8 F, 18 x 9 R and +35 offset. I think that combination is quite nice for GTT. The problem is the 57D ONLY come with +38 or +22 offset Is thinking of 18 x 9.5 +38 F and 18 x 9.5 +22 R, or +38 all round? Planning for using 245 40 F and 265 35 R tyres. I am after something without guards roll, no stretch tyres and no massive camber. Please help Thank you.
For anyone that is interested, I went with the 18x9 +18 all round.
Skyline model = 1998 R34 GT-t
Wheel model = Enkei RP03
Wheel diameter = 18
Wheel width = 9"
Wheel offset = +18
Tyre size = Front 245/40, Rear 265/35
Modifications to fit = None
Here is the result (looks pretty good methinks...)
I've been thinking about getting a set of rims that look good, but didn't necessarily have the width that I would have liked. it comes in 18x8 19x8 and 20x8.5.
Now I know most people seem to at least run 8.5 on the rears. I would like to do much the same, however with the available sizes, that would mean running 20" rims, which I don't intend to do.
Would anyone still be able to recommend 8" wide rims as nice; or is 8.5"-9" have particular advantages I'm not seeing atm?
Skyline model = 1997 R33 Gts-t S2
Wheel diameter = 18
Wheel width = F 9.0/R 10.0
Wheel offset = F +45/R +48
Tyre size = F235 / 40 R275/35
Modifications to fit = None , but it doesnt fit! Tyres hit on the inside, How big spacers would I need to get this to fit?
One more question
To sit absolutely flush on a r33 gtst s2 , which tyre size and offset is most preferable with only mods required being rolled guards. Scanned over 45 page of this thread but unable to see if a general consensus had been reached.....
20mm front and back should be good..25 would be ok too..are they andypandas wheels??
he had exactly the same size for sale.....theres pics in his sale thread...i believe he was running just 20mm spacers at the front and it sits pretty good
here it is..
http://www.skylinesaustralia.com/forums/topic/382672-wtt-volk-f-zero-18s-with-near-new-federal-595-rs-rs/page__p__6104041#entry6104041
here it is..
http://www.skylinesa...41#entry6104041
wow , you have no idea just how helpful that was :)
No these are completely different wheels but with the exception of not being white, they are exactly the same....I had them on my supra for the past 2 years and they have 275's at the back.
with the 275's , would 20mm spacers still be adequate so it has sufficient inner clearance?they are hitting pretty bad right now to the point of not even having enough space to bolt the wheel on.if not will the 25mm spacer suffice? Id prefer to fit these wheels then swap them
something like this?
http://www.ebay.com.au/itm/NEOTECH-NISSAN-5-Stud-114-3-25mm-Bolt-Wheel-Spacers-/130708637330?pt=AU_Car_Parts_Accessories&hash=item1e6ed78692
Edited by tripsteady
Hi, i'm struggling to determine whether or not the following will fit:
Skyline Model = R33gts SII (n/a, 4x114.3 hub, puny calipers)
Wheel diameter = 18"
Wheel width = 8" front - 9" rear
Wheel offset = +30
The wheels i want to order are called Wolf S1P's
http://www.wolfwheels.co.nz/wheels/high-performance/s1p.html
anyone running a similar size/offset? opinions on the offset? Will they fit ok? If so what size rubber
Love this thread, help really appreciated, thanks.
Wheel offset = +30
http://www.wolfwheel...rmance/s1p.html
Those will fit.
Tho as usual, depnding on ride height, camber n tyres- fronts might rub the guard at full lock especially with suspension load. Rears might need the guards rolled.
Nonetheless, should fit well/look good.
http://www.ebay.com....=item1e6ed78692
Mate, those are massive wheels for a GTST (and tyres).
While you may be able to get them to stop hitting on the inner with spacers they are going to stick out like bulldogs balls and certainly require considerable guard + suspension mods just to not hit the arches...
dammit , and i thought the r33 rear end looked fat enough to handle 275's. I plan to roll the fenders but didnt want to mess with the actual bodywork of the car...
sorry to be such a noob and ask again but can you confirm that 275's rarely ever get put on r33's unless guard work is done?
well it is fat enough n it isnt...
N funny you should ask. I run 275's on the rear of mine...
but there are a few things you have to take into account. my rim is 18x9.5+36. Which is about as good/wide as it gets for an R33 GTST when all other things have been considered. Any bigger/further in n you are going to be coming close to suspension n guards etc. Any further out n it will stick out from the guard.
I have had to completely cut my rear arch lip out to get these to fit. As you can see from the pic it sits EXACLTY flush with the guard (at the top) but the tyre does stick out further down the arches- so technically defectable, but its sticking out overall n at the top that is the main issue for a defect. n the boys have never bothered me about how mine slightly stick out. See pics attached
The second issue is that alot of people will simply run alot of camber to get big rims n tyres inside the arches. Well, ok, that works, but basically you are reducing the handling of your car AND chewing through tyres very quickly (and expensive tyres at 18"x275)- Its just not worth it.
Finally, have you ever used spacers before? often they will never sit perfectly and balanced which also means that you get some interesting handling characteristics and steering vibration. Oh yeah, n spacers are another thing to get defected for...
so technically , to get flush fitment , if I could buy the perfect rim (which for me would be something deep dish) it should be 18x9 +36 at the rears with 265/255's? What else would give close to flush fitment while filling out the bulging arse end of the 33 without any more mods then rolled fenders? and do 235's at the front do the job and sit flush? scared to mess to much with the front as those two wheels move a hell of a lot more then the rear :)
the fronts on R33's are a funny thing... having rims that sit flush means rubbing on the guards under turning/load. Iv got 2 skylines. 1 is getting close to flush and rubs (tho i would say not badly at all and very tolerable) with 17x8.5+32 with 235's. The other (car in the pic above) sits in a bit (i.e. is not flush) and does not rub at all- on this the rims are 18x8.5+36 with 235/35/18's.
Im sure once again camber or getting stuck into the front arch guards might fix it but thats cheating in my books, and fronts with camber on a street driven car will chew out sooooo quick.
does your car have coilovers or is lowered?
Edited by jjman
how do u reckon 17x9.5+18 will sit,
Pics would be amazazing!!!
Good on the rear, maybe a bit mexicano on the front.
I had 9" + 22 on the front and they sat just about flush with pumped guards. Those offsets stick out 10mm more.
well I do plan to add a small amount of camber but this is my daily driver so above all I aim to have stock drivability and comfort nothing to harsh , and certainly nothing that's going to rub at all.Don't mind being slightly above the guard if the front is going to rub.
No i have no coil overs or anything right now - deciding on which one to buy , the bc v1 look good. Wanted to get the wheels first so Il know how much to lower.....basically i want it to sit flush without rubbing anything with the only mods being rolled guards. Seem to think this is impossible now :(
I run 18x9.5+12 w 235/40/18 allround, tyres tucked. not cambered and not flared... I get no scrub... it's all in the guardwork
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
