xd9's look best in 17x9.5+17 fr and 18x10+18r
you can go either of those sizes all round, but if you want the 18's all round be prepared for a decent amount of wok to get the fronts to fit,
Skyline model = R33 Gtst
Wheel diameter = 18" Rays Gram Lights 57Gainer
Wheel width = 9.5"
Wheel offset = +22
Tyre size = 235/40/18.. Nitto NT05 front, Federal 595 rear
Modifications to fit = all guards rolled
Haven't really seen many 34 gtt's with aggressive fitment so thought i should venture to push the envelope on fitment.
What are thoughts on running 18x9.5 +19 Fronts and 18x10.5 +14 rears on 225/40 front and 235/40 rear tyres
What sort of guard work do you guys believe would need doing and opinions on the matter
Edited by Akshay
Thanks bud, just stock arms but I've got some bushes in the back to pull a bit of camber out.
Maybe -2 or so?
cool.
Iin the photos, it almost looks like the front poke a little more than the rears.
Did you have to roll the guards pretty much flat? I always thought the guards would need a light pull front and rear with those sizes but they dont seem too bad in terms of how much they sit out of the guard either.
Any chance of some front and rear pictures in line with the side of the car that show exactly how much they sit out?
cool.
No pulling/pumping, only rolled the lips up.
I'll get some pics up soon
What suspension HEKT1K? Do you get any scrubbing over bumps up front or anything?
Tein Super Streets atm... but they are pretty much stuffed, so I'll be upgrading to something a bit stiffer soon
Doesn't really scrape unless the wheel is turned, going up crappy driveways etc. I'm sure with some harder coilovers it will be even better
That fit is prefect. I can't believe they fit that well with just a roll!
How do you think the rear would go with a 255/35? Probably need a pull to get it under you think?
18x9+7 front 18x9.5+7 rear
awesome fitment im looking at 9.5 +15 all round on 235/40/r18. So 2mm further in on the front and 8mm further in on rear. How much camber are you running and what work did you do to the guards.
Cheers
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
