xd9's look best in 17x9.5+17 fr and 18x10+18r
you can go either of those sizes all round, but if you want the 18's all round be prepared for a decent amount of wok to get the fronts to fit,
Skyline model = R33 Gtst
Wheel diameter = 18" Rays Gram Lights 57Gainer
Wheel width = 9.5"
Wheel offset = +22
Tyre size = 235/40/18.. Nitto NT05 front, Federal 595 rear
Modifications to fit = all guards rolled
Haven't really seen many 34 gtt's with aggressive fitment so thought i should venture to push the envelope on fitment.
What are thoughts on running 18x9.5 +19 Fronts and 18x10.5 +14 rears on 225/40 front and 235/40 rear tyres
What sort of guard work do you guys believe would need doing and opinions on the matter
Edited by Akshay
Thanks bud, just stock arms but I've got some bushes in the back to pull a bit of camber out.
Maybe -2 or so?
cool.
Iin the photos, it almost looks like the front poke a little more than the rears.
Did you have to roll the guards pretty much flat? I always thought the guards would need a light pull front and rear with those sizes but they dont seem too bad in terms of how much they sit out of the guard either.
Any chance of some front and rear pictures in line with the side of the car that show exactly how much they sit out?
cool.
No pulling/pumping, only rolled the lips up.
I'll get some pics up soon
What suspension HEKT1K? Do you get any scrubbing over bumps up front or anything?
Tein Super Streets atm... but they are pretty much stuffed, so I'll be upgrading to something a bit stiffer soon
Doesn't really scrape unless the wheel is turned, going up crappy driveways etc. I'm sure with some harder coilovers it will be even better
That fit is prefect. I can't believe they fit that well with just a roll!
How do you think the rear would go with a 255/35? Probably need a pull to get it under you think?
18x9+7 front 18x9.5+7 rear
awesome fitment im looking at 9.5 +15 all round on 235/40/r18. So 2mm further in on the front and 8mm further in on rear. How much camber are you running and what work did you do to the guards.
Cheers
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
