Looks mint! I cant believe the 265's sit like that on a 9.5 +22, especially on the front. I think when i get new wheels, ill run a thinner tyre on the front and dial out a bit of camber to help with tyre wear.
What was the reason for the 7mm spacer in the rear? Inner scrub issues?
Nah no scrub, just had the space to push it out a bit more. If i bought these wheels new i would have got +15 for the rear
I have a 93 R32 GTST Type M, wanting to run 17x8 +28 rims (Work meister S1 2P). Any guard work needed? Will they clear calipers? Car has coilovers but very little camber adjustment as mostly stock suspension arms. Anything else I should know? Really want to avoid flaring/pumping/stretching guards at this point...
Has anyone got an example of the following on a 33 gtst
18x9.5 +27
18x9 +27
I saw the example last page of the white 33 with +22
How similar are these going to look because his looks amazing and exactly what I want but the rims only come in +27
Hey guys..
Just been searching through a few pages but yet to come across any confirmation..
Looking to see if the following will fit an R34 GTR,
19 x 10.5 +22
Cheers
I would have thought you would have scrubbing issues on fronts. I could be wrong though.
18x9.5 +27
18x9 +27
Assuming same width, yours will have 5mm less poke. Nothing to be too concerned about.
So to the eye it will pretty much look identical.
If I run the same width as him of 9.5 and same tires.
From what I read it will just need a roll on all corners
Yeah 5mm here or there won't make or break the look dude.
9 +27 on the front may not even need a roll, depending on height etc, but for the extra $100 you might as well get it done
Trying to make up my mind between 9 or 9.5
Not worried about having to roll the guards but
Are any other offsets available? You could run 9.5 +27 all round, fronts might have some inner clearance issues though
I'm just looking at Rotas rims because im a cheap ass.
They have a few of their grid range in +20 etc
I was looking at the BOOST 18 9 5x114.3 27
But I don't mind running 9 if the 9.5 has inner clearance issues.
9.5 and 9 mean the offset will be different, and for the sake of half an inch you are better off going 9's imo. Unless he specifically ran 9.5s with no issues.
9.5 + 27 = 9 + 22
Wider rim = less offset needed to poke the same amount, but then you get clearance issues. I want to run 10.5 all round but fronts will rub.
Edited by voncina
Because I don't want the clearance issue I would prefer the 9+27
Edit: used the calc and there is a 6mm difference between the 9.5 and the 9
So that means of the 9.5+27 is around 5mm difference to his setup
Then 9+27 will be about 11mm difference to his setup which will remove a bit of poke but still have a nice flush stance.
Will the fronts be flush with 9+27
Edit again: f**k I love this calculator finding so many good combos that are similar to his such as 9+20 only has a 4mm difference
lol kasko, if you want to see an example of how 18x9 +27 sits looks for photos of 33's with r34gtr wheels. They will poke 3mm more then those... Itll fit nice IMO
If you want to go 9.5 on the front, you have to go low 20's in offset for inner clearance, so you will get a bit of poke but as the pics on previous pages show it looks tough.
Look at it this way, the difference between 9" and 9.5" is 12.5mm. Therefore in the same offset a wheel that is 9.5" will be 6.25mm wider on each side of the wheel, than a 9"
Edited by Mitcho_7
Kasco just go 9.5+27 all round.
if you go back probably 12 months in this thread there's a pic of my car with 9.5+25 all round
Tried looking through to find it.
I guess you didnt have any clearance issues up front?
Rota also offer 9.5 + 20
Could go that if you were feeling a bit more ambitious
I keep looking at this but I dont want to have heaps of guard work.
Might test fit some 9.5 +20's when I lower the car to where I want
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
