GENTS THE MOST URGENT OF HELP IS REQUIRED......
im about to purchase some rays sebring, heres the details
18 x 8.5 +40 front
18 x 9.5 +45 rear.
will these FIT A 94 GTST.......................help me ladies and gents!
Depending on whether you prefer the wheels to stick out more, or sit nicely in the guards. However, with those offsets, the wheels will be sitting right inside the body, and it might look a bit weird.
Not only that, as someone has already mentioned, because of the widths of the wheels, such a high offset may cause clearance issues on the in-side of the wheel, ie: fouling on suspension components.
I would say that the front will very likely fit, but the rear is anyones guess.
A safer, and better looking offset (in my opinion) would be anything between +36 and +30
They'll fit, but....
I've got 18x8 +42 all round ('94 R33 GTST). There's about 5-10mm clearance inside to the upright on full lock (need to get out and measure this properly), and rears have about 25 mm clearance inside.
Mine looks anorexic though, which is why i've been trawling threads like these for the last 2 months trying to work out best fitment for a new set.
The lads are right, if you're going to get new wheels; might as well get a lower offset.
If it helps, here's what i've measured on my car:
Fronts
Hub to flush with guard ~84 mm
Rim edge to flush with guard ~24 mm
Inner clearance ~8mm
Rears
Hub to flush with guard ~94 mm
Rim edge to flush with guard ~34 mm
Inner clearance ~25mm
You should be able to use these numbers to see how different width and offsets will sit in relation to the guards and suspension using one of the offset calculators on the web. I'm pretty sure these numbers are accurate, but I hold no responsibility if they're wrong! ;)
Finally, in my opinion for what it's worth, don't shell out for those Rays unless you've really got your heart set on them. The fitment won't be that great.
18x9.5 +15 with a 235/40 18. guard lip rolleds up 100%, camber is set at - .2 with whiteline camber arms, about 3mm off guard, will put camber to -1 before the next track day. front is -2.5 camber, hits guard liner, no big deal
Do you have any scrubbing on this, i dont have any camber arms but i hope i can the same sizes ok
The post is right there, how can you not read..
You will need camber arms for this exact fitment, if you don't, you are going to have to raise your car a lot for your fronts to clear. And he said there were no scrubbing issues except for the front liner. If you are lucky, you will have coilovers that allow up to 2deg camber, then you can do this without camber arms.
I run 18x9.5+12 all around. You will need to get your guards rolled all the way and pulled slightly. I'm not running any camber arms it's stock suspension apart from coilovers.
You might need to remove part of your front / rear guard lining. You might get slight scub on full lock shouldn't be an issue. I didn't have that issue as all my guard lining has been removed. It depends on how low you want your car.
Edited by DarkRyda
Skyline model = R34 GTT
Wheel diameter = 18
Wheel width = 9.5 fronts, 10.5 rears
Wheel offset = +22 fronts, +30 rears
Tyre size = 225/40 fronts, 245/40 rears
Modifications to fit = Guards rolled all round, coilovers to drop - not needed though. Can probably afford to slam the car a little more, but happy where it is for now. Poking about 3 mm all round. Perfect fitment in my mind. No scrubbing issues, except on full lock - fronts hit the liner, which is no issue in my mind. Will upload better pictures when I get the chance.
Edited by voncina
wont need the camber arms... the front guards are soft as all hell and will easily accomodate 9.5+15 w 235/40 if pulled enough
thanks mate for an informative reply unlike some people here which seem to be having their period this month
I said IF (->IF<-) you wanted that EXACT fitment you would need camber arms. Sorry for me trying to help you, ungrateful douche.
^^ Looks awesome mate, keen to see more pics of the car further away to see what it looks like. Also, are your rear lights tinted?
Yeah they are.
I have a track day today. More then likely there will be some nice shots of the car from afar. I will get some good ones up later on in the weekend. Fitment is almost perfect [=
Edited by voncina
^Mate, looking good. keen for more pics, needs moar r34 :P.
In other news, figured out my offsets a while ago, just haven't had any time to consider it further... so busy these days, sigh. They should be 17x8 +35 all round, with 225/45 tyres all round I believe.
Recommendations for some spacers size for some flush fitment? (Guards will be rolled if going flush).
Safe but as flush as possible fitment with those rims, I would go 25mm fronts, (30mm if you are daring, still won't poke as much as my rims if you do go 30, but you will be close.) and for rears 35mm would be very close to my fitment as well. Factor in some camber for when you drop the car, and she should sit quite nicely.
And yes I do know my car is dirty and has swirl marks, etc etc. Working on it.
Edited by voncina
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
