Okay so it has come down to the day of actually pretty much buying my rims.
Starting to get cold feet!!
18x9.5 + 22 like what Hectic is running
or be a little safer and go
18x9.5 +30
I CANT CHOOSE!
The +30 will be a little better for not getting police attention.
Would the guards still need a little roll even if I am running camber from my coilovers
I have some XT7s on order, 18x7.5 +35 fronts 18x8.5 +32 rear. Just wondering what size tires you guys recommend for a nice fit for these rims. I'm not a fan of stretched or balloon looks
What do you think of toyo proxie 4s?
I'm kinda a granny driver lol but I occasionally give it a squirt. My r32 is basically stock, just an FMIC an uped boost, at a guess 160ish KW
The kumhos, are they a soft compound? How much are they roughly?
Im getting some racing hart rims for my R32 GTR and want to know if they will fit.
They are 19x10.5 +15
Ive been told they will fit. Ive looked up the jap site for the rims and think they might be 19x10+15 tho.
Anyway will these fit under my car?
What mods will be needed so theres no probs?
I would be keen to get that checked. That is a VERY large rim for the 32gtr. 33/34 R's may be able to run them but I am under the impression the 32 guards are smaller then 3/4s. Can anyone back me up on this?
Found out they are 19x10+17
Trial fitting tomorrow then choosing the tyre size. Bloke reckons prob 265 max on there.
Will put up pics when fitted. Fingers crossed. Definately going to fill the guards. lol
Yeah, even 265's may be a sqeeze. I got 245 running on 10.5 and it has decent stretch, but not too excessive. 265 is the optimum size (I do believe) for 10's. Do 32 Rs come with 17's from stock?
I ended up swapping my CR Kai's for Buddyclub P1 Qf's. My only concern now is that I've gone from a +22 to a +17 and haven't had a chance to trial fit. Will they fit ok? Will I have an issue if I want to upgrade to bigger brakes in the future?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
