code of practice states diffrerent
Sorry but no.
The wheels must be contained within the bodywork, or mudguards (including flares) when the
wheels are in the straight ahead position.
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP11_Section_LS_Tyres_Suspension_Steering_V2_1Jan_2011%20v3.pdf
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx
And the code is still in draft and live so it does not come into play legaly, your state authority guidelines are the ones you must comply with.
Its a good read though.
wrong!
it already has....the standards must be met when engineer the car....we can have this debate all day but ive spent the last 6 months working on this and won...not to mention that my car was engineered in sydney to those rules
wrong!
Well then how about a link to said docs, as during my engineering process this came up as well, all the information I have come up with states that you cannot have wheels or tyres outside the body line, this is also what my engineer said, but if you have some new relevant information that can be backed up by a legal document that the local (i.e NSW RTA for example) will use for compliance then I shall be proven wrong.
Until then just saying Im wrong holds no weight.
these regulations are a standard and are live....all cars (including modified must meet these) and YES these are not drafts these are the CODES that must be met
as i said i spent the last 6months in court over this exact thing and have the documents to prove it how ever i see no need to show these to you to prove you wrong...
Sorry but no.
http://www.infrastru...n_2011%20v3.pdf
http://www.infrastru...n/vsb_ncop.aspx
LOL
Your link was the one I posted up before, YOUR link states.
LOL
2nd to that i never stated anything about that link saying otherwise....
NCOP11 Section LS Suspension and Steering V2 01Jan2011 [dl_acrobat.gifPDF: 1319 KB]
4.2.3 Clearance
No part of the wheel must touch any part of the body, chassis, steering, braking system or
suspension under any operating condition. To check this, the vehicle must be fully laden and
capable of negotiating raised obstacles that would normally be encountered whilst driving such
as speed humps and driveway entries. This test should be conducted from lock to lock without
any part of the rim or tyre contacting any other part of the vehicle. Test weight for passengers is
68kg plus 15kg per person for luggage where luggage space is provided.
Section LS Tyres, Rims, Suspension and Steering
Version 2.0 – 1 January 2011 Page 21/LS85
The wheels must be contained within the bodywork , or mudguards (including
flares) when the
Steering and/or suspension stops must not be modified to provide clearance for wheels.
Skyline model = R33 GTS
Wheel diameter = 17"
Wheel width = 9" front 10" rear
Wheel offset =45 on rims using 30mm bolt-on spacers = 15 offset
Tyre size = 235/45/17 front 255/40/17 rear
Modifications to fit =roll guards
Edited by viinnh
01Jan2011[/i]' timestamp='1358223891' post='6707258']
the vehicle must be capable of negotiating raised obstacles that would normally be encountered whilst driving such as speed humps and driveway entries.
Wondering on fitment for r34 with no problems and unrolled guards?
18x8.5+25
18x9.5+35
thanks
if it is stock height that will fit no worries, even with full sized tyres to the rims. Tho it may rub on the plastic splash guards in the fronts when turning hard, but it isnt hard to do that anyway. Nor is it a problem.
If you lower the car you will need to roll the rear arches.
I had 34R wheels on which are 9.0 + 30 with no dramas, new rims are a 9.5 so hoping all should be ok
didnt you check what clearance you had then when you had those rims on? that way you would easily be able to tell what ur working with.
Also your wheel alignmentsetup is going to play a part so what might fit on one car will rub on another...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
