Guys,
Im looking at ordering new wheels soon.
Anyone have experience running 19x10.5 + 12 wheels?
Any rubbing front/rear?
Was also thinking about going 19x11 +12 at the rears. Anyone run this before?
On a R33 GTR??
you want the same all round for that.
10.5+12 will be maximum
ofcoarse you can run any brake size with 19s
I've seen brakes not clear 19's on a r34 gtr, he had to get specific 19's but mostly ran 20's. Dunno what brand of brakes they were but 8 pot fronts and 6 pot rears, set him back around $15k I believe.
woooooooahhh
thoughts on 18x9.5 +22 front 18x10.5 +30 rear?
been reading through pages and pages but haven't found anyone running 18x10.5 +30 on the rear. will +30 be a problem with the strut or inner guard?
i want to run as close to 0 camber as i can
Hey guys,
I have never been completely happy with how my 18x9.5 +22 rims sit on my car.
So I decided to call up the place who did the wheel alignment and get the specs for the camber that they put on it.
Below are the details
Front Left: -2.27deg
Front Right: -1.14 deg
Rear Left: -1.39deg
Rear Right: -3.69deg
Does this sound right? I always thought 3deg camber was something the fan boys did
I'm questioning if he actually gave me the correct info.
Looking at some whiteline camber arms to help correct this.
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
