Skyline model = R33 GTR
Wheel diameter = 17 inch
Wheel width = (F) 9 inch (R ) 9 inch
Wheel offset = (F) 30 (R ) 30 ---> (F) 10 (R ) 10
Tyre size = (F) 245/45/17 (R ) 245/45/17
Modifications to fit = None
AFTER / BEFORE
1077752_10151761186247326_658129955_o.jp
Daniel - that's out of whack mate.
Front L+R and Rear L+R numbers should be pretty close to each other.
eg:
Front L = -01.85 R= -01.86
Rear L = -02.26 R= -1.99
So yeah fractionally different - not whole numbers apart
Edit: 3 degrees probably to much for the street. Fine for the track
Depends how much tyre wear you can bare.
Hey guys,
I have never been completely happy with how my 18x9.5 +22 rims sit on my car.
So I decided to call up the place who did the wheel alignment and get the specs for the camber that they put on it.
Below are the details
Front Left: -2.27deg
Front Right: -1.14 deg
Rear Left: -1.39deg
Rear Right: -3.69deg
Does this sound right? I always thought 3deg camber was something the fan boys did
I'm questioning if he actually gave me the correct info.
Looking at some whiteline camber arms to help correct this.
Edited by Sinista32
Okay awesome.
So they have bushes that allow you to adjust up to 0.75%
I was thinking of getting them for the front
And camber arms for the back to adjust the most.
What do you think?
Or should I be getting camber arms for the front as well.
front has no movement, but rear has a few degrees of adjust. camber adj blocks at the front will be fine, but you will need the arms to fix that rear. But that leads to the question, why is the car so far out at the rear? is this as good as they could get it? or is it just a dodgy alignment job?
I'm really unsure what happened.
I took it to a local Canberra tire place.
Seems very strange that they allowed it to be so different for both sides. Makes traction very strange in the wet. I was thinking with arms I could get it to almost flush.
Yeah rears shouldn't have more than a degree or 2 at most..3 on the front is fairly common, I run it but not on the back...and they shouldn't be that different side to side..half a degree at most...sure you haven't got a bent control arm...
It must look odd from behind your car...
For good handling you want r 2-3 on the front and 1-1.5 rear...for good looks you want to wear a dress and heels..
AFTER / BEFORE
needs more low!
:thumbsup:
  • Like 1
Hey guys,
Rear Left: -1.39deg
ouch!
This is on the money
this is a little too much on the rear as far as static camber is concerned in the rear regarding traction and handling.
if you come up the coast i have a guy that can do your car ;)
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
