The car is up high as hell at the moment but will be lowered to the legal limit in a month or so. itll be 18 x 9.5 +25 offset for both the front and rear as i cant find any smaller =[
So 235s on the front and back? Also what does a roll mean? I dont know that much about these kinds of stuff.
I just got a set of d1rs
18 8 +35
18 9 +15
Running 235/40r18
They didn't fit rear at all stuck way out and looked very dim
Now I and swapping for some
18 8.5 +30
18 9.5 +22
Will be still running my 235/40r18
Just wanna make sure new wheels I am swapping for will fit?
I have looked and looked. But nothing really
Have coilovers
And is a r32gtst
Can any confirm that
New wheels will fit?
Hi all...wondering if someone can help answer these questions...
1) the R34 Z tune. Was it flush with the Z tune front fenders?
2) they used rear fender covers.. does it mean that the Z tune offsets made the rims poke out of the BNR34?
I ordered myself two rims for the 33gtst. I got Rota grids 18 x 9.5 + 18 and i am running them on the front. My car is all standard suspension and steering wise, just lowered and it runs perfectly and only just scuffs the liners on big bumps and hard cornering. So i took the liners out and i could probably just file them down on the high spots of the liners but just leaving them out. Then my next problem was the wiring on the inside of the drivers guard and was worried it may hit it. I cable tied them just to be sure and used a white touch up paint on the cables that looked at risk and painted them to see if it would get rubbed off and it didnt, so all in all a good fit and looks awesome with a white car on matt black Rota's wheels and they have a little stretch which is good on a 235/40 tire. Would normally if this fitment were to be transferred onto the rear with the + 18 thats on the front, are they meant to tuck in more than the front or meant to stick out more on the rears with exact same offset?My car is lowered but rear end is a bit higher so just seemed the same and couldnt really tell, just assumed they would tuck more than the front
not sure how low your car is - i had to run adjust camber on the front to get them to fit and not rub and im running the same specs as you. The rears should tuck in nicely and you should have no probs running a 245 on the rear
that will fit. getting your guards rolled professionally would be needed - you can youtube it. you can go 245 or 265 on the rear
Can we PLEASE PLEASE stop buying rota and varrstoen or any other knock off wheels....
Its like almost paying full price for a pair of Jordan or Air Max knock offs from ebay. You can buy Enkei or other wheels from SAU sponsors for about the same price. If you want any other decent jap brands contact jesse streeter http://jessestreeter.com/
Not this argument again. You can buy brand new 18" Rota Grid's for $999. In Australia, ready to ship. Compare that to a set of 18" TE37's, you're looking at over $2000, and a 9+ week wait ex-japan. And no the quality might not be the same, but neither is the price.
Everyone should just buy whatever they want.
Edited by colourclassic
I know this has been overdone a million times but im about 20 pages in and i still cant find someone with the exact fitments im looking for, ive bought a set of te37 super laps in 18x9.5+22 for my r33 gtst and now im not sure what tyres would fit exactly without scrubbing or maybe a tiny little bit worst case scenario, ive narrowed it down to a 265/35 for the rear and 235/35 for the front. Both front and back guards are rolled as well. if any one can shed some light if i can do those tyre sizes that would be great!
also is it true that 35 is the rolling diamater for a r33 gtst or can i go up to a 40 profile
Cheers
Ah really haha, weird. I just measured the bottom of my front bar from the center and it was 163mm, what is yours? mine isnt all that low i guess even though its on lowered springs haha. My center muffler is sitting just under 100mm or so :/ need a resonater instead. So your using the same wheels? did you get the lip rolled on the rear coz mine rubbed when i tried it out on a quick drive.
Cheers
My 33 gtst is running the same spec rims.
I'm running 235's on the front and back for ease of fitment.
All I needed to do was a little roll of the guards and removed the guard liner.
Not sure how 265's would go on the rear.
I guess it depends how low your car is
Cheers
The 235/35 would be a smaller rolling diameter than the 265/35s. I believe 235/40 is closer to the stock rolling diameter, and also a more standard size I think...
I'm running 235/40 front, and 265/35 rears.
I ordered myself two rims for the 33gtst. I got Rota grids 18 x 9.5 + 18 and i am running them on the front. ...
Got any photos? So many people fitting new wheels, not so many posting the results... :(
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
