Where is it scrubbing? It shouldn't be with those tyre sizes. The offset seems a bit high, might be scrubbing the front part of the plastic guard cover (if you're running high caster).
FYI I'm running 275/35/18 on 18x10+20, just touches the bit where the bumper is mounted to the guard (rolled guards). I could just raise the car to stop it :P.
  • Like 1
Quick question:
Will 18x9.5 +23 fit the front of an R33 without rolling or removing the splash guards? Looking at running either 225/40 or 235/40.
I've got no issue with rolling the rear guards but I don't want to mess up the front. Car sits with about 2-3cm between tyre and arch so not super low.
Currently running 18x9 +30 with no scrubbing at all.
Quick question:
Yes.
I don't wanna mess with the guard liner/front guards because a) it looks shit when it's missing and b) shit gets into the quarter behind the wheel. I'd rather just leave it untouched.
You are just rolling the lip on the fender.. Not missing the plastic lining... There are almost no downsides to getting it done.
Meh... bin it
Hey guys, im in the market for new rims and im a newbie when it comes to offsets so ive come to you guys!
My 33 has not had its guards rolled and sits at a pretty well standard height for the moment but will be putting some BC Coilovers in at the same time or shortly after i get wheels!
wanting to put the following on and Id like to know if i can run them safely without any scrubbing and to clear the struts and calipers and to not be sticking out the guards too much! (or is that too much to ask lol)
Tyres 235/40/R18 all round
Front : 18x8.5 or 18x9.5 + 22 to + 35 (roughly)
Rear 18x9.5 +22 to +30 (either or in between)
im after the most aggressive deep sort of look on my car, so any reccomendations and or opinions would be great!
looking at getting some varrstoen Es3's or Es6's or some Rotas..im too undecided there all so good!
Cheers!
Front : 18x8.5 or 18x9.5 + 22 to + 35 (roughly) go at least +30-22. Will need rolled guards. Varsstoen have low disc so I'm not sure they will clear calipers.
Rear 18x9.5 +22 to +30 (either or in between) will be fine, a little poke.
  • Like 1
So I think I've finally decided on a wheel size that I want for my R34 gtt 18x9.5+20 all round. (Now just need to find some BBS RGR's)
The thing is, I wanted to go with the same tyre size all around too, I couldn't find anyone or anything on the forum, but has anyone run 255/35 on the fronts? Closest I've seen was 245
Edited by tiddyd
Plenty of people have but you would be better going with a higher quality 235/40 if its a street car as it will grip just as well and will be lot easier to fit. Unless you are running 400kw or something crazy
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
