RB20DET, Stock turbo 15psi 164rwkw
City: 470km's per ~50litres. That is until the red light first shows.
Open Road: Not sure have never taken it on a full tank.
WOT: Booting it the RB20DET would drop fuel economy to low 400's per tank.
Driving style didn't appear to make much difference to fuel economy.
RB30DET - Stock rb20det turbo 176rwkw 9psi.
City: 450km's per 50litres.
Open Road: Again. Not sure.
WOT: Booting it the RB30DET drops to 380km's per tank.
I'm scared to start swapping out the stock injectors incase fuel economy goes to the sh*t. :D
Mind you Bl4ck32 has 550cc rx7 injectors thats all been tuned up, his rb30det in his r32 tends to get slightly better fuel economy than mine.
Edited by Cubes
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1541740
ive found a trend in my car. it's basically always KMs/10 + 10 = Litres of fuel
so 350kms = 45L filled up
400km = 50L filled up ... and so on
my 33's usage was similar
so far ive only had one tank which was used for pure thrashing and i did about 250km in 55Ls :D
freeway driving is typically a lot better than the formula above.. the other day after filling up, i drove 130kms. then i pulled over and filled it up again, and i only put in 16Ls..
edit: i just realised that the above does not apply to u as i have an rb25det in my 32.. lol sorry.
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1557199
Hiya,
I've got an R32 GTS-t manual and I get roughly 380-400km out of the tank of regular city/suburban driving.
just did a drive up to Sydney and back a few weeks ago before that dreaded fuel increase and estimated with general cruising averaging 115-120km/h I could get around 600km to the tank.
Mind you though the car's running an aftermarket replacement ECU and it doesn't run an airflow metre anymore so I was expecting it to drink more than that... :)
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1563157
  • 2 months later...
ok i should mention this isnt untill the light comes up...
probably a touch above E
Im with you silver gtst..... i like to fill up before the sludge in the bottom of my tank strts clogging up the injectors!!!!!
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1757525
Fuel tanks get a build up of crap over the years. A friend of mine had a vl turbo that used to run really rough whenever the fuel gauge went below 1/4. Thats the worst I've ever seen.
You could fix it by taking the fuel tank out and cleaning it out, but that is just sooooo much effort, much easier to just keep a nice amount of fuel in there. :)
https://www.sau.com.au/forums/topic/85093-r32-gts-t/#findComment-1762131
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
