well?????????????????????????????????????????? was it hubby lol
hahaha i wasnt suppose to say anything but................:( the wire he connected it to was labelled "speed wire"..i pointed the label out to him and i couldnt stop laughing :happy:
oh well i couldnt have done it my self so im greatful that i have a radio, it works when i plant my foot down and that he did it for me :mad: we all make mistakes and were not perfect but it sure was funny seeing the wire labelled :laugh:
:laugh: ya brett :huh:
*Shrugs shoulders* Meh it had 12V on it when turned to accesories so I used it... Have to admit though I am not sure what the purpose of a wire coming from the radio that varies its voltage as the accelerator is pushed for.... never the less... I redid it and used another wire... problem solved :D
*Shrugs shoulders* Meh it had 12V on it when turned to accesories so I used it... Have to admit though I am not sure what the purpose of a wire coming from the radio that varies its voltage as the accelerator is pushed for.... never the less... I redid it and used another wire... problem solved :P
Your right - that is weird....
Maybe it is one of those things like Honda and BMW fitted to their bikes a while back - the big tourers that had stereos fitted as standard (I kid you not!) had a natty little feature that raised the volume as the road speed increased so you could hear your choons over the wind noise.
Yet another trap for young players in the wonderful world of japanese imports :D
Well what it appears to me is that when the throttle is pushed (only in drive, not park) the voltage appears to drop across that wire... thus the Fm Converter doesnt have the power to work...
Its the strangest thing I have seen in all my years of backyard auto electrics :D
  • 1 month later...
Bought a head unit today, and some rear co-axials to match my front Boston splits. Hopefully, I will fit these next week some time.
My front speaker mounts had to be chopped up heaps too for the magnets to fit, and some of the mounting holes didn't line up properly. I might have to borrow a jigsaw and get some MDF to make some decent pods for them, and maybe the back too depending on the quality of the fit.
Has any one worked out how to get decent reception with aftermarket head units and the aerials in the rear windows? The only wire I have that isn't connected to anything is blue with a white stripe but when I give that 12v it doesn’t make any difference to the reception but sucks up a heap of power as if it's earthed.
The black with yellow stripe wire that Alexcim claims is the power for the antenna is connected at both ends. One end joins into the wires going to the antennas and the other links into the main body loom.
I guess my next step will me to snip the black with yellow stripe wire and give the end going to the antennas 12v and see what happens.
Hi, did you get around to trying this? Did it work?
:P cheers :P
Yet another trap for young players in the wonderful world of japanese imports :(
The 350Z also has a similar feature. You can have the radio get louder as your revs increase. Not sure if that would work in practice but it would be interesting to find out.
I found that you have to hard wire both connections coming from both diversity antennas together and into a standard plug to get the best reception. If you just use an adaptor plug, you will be only using one antenna.
Heres some pics of the adaptor I made, just make sure you insulate the centre cores from the screens when your done soldering them together, or you'll end up with no reception.
Might stick some heatshrink on it, to tidy it up, and make it more secure.post-17348-1172144501.jpgpost-17348-1172144863.jpg
That is what I did too as I couldn't buy an adapter at the time, that was a stroke of luck. Powered up the yellow and black wire and I am happy with the reception I get, Just as good as our other car with a standard external (maybe a little better).
Cheers
Luke
Cheers
Luke
That was lucky, it's the only way to get decent reception. I've found it's not quite as good as a normal antenna, eg: if you go in an underground carpark etc, you completely lose reception, and won't pick up quite as far over distance, But it's damn close.
Cheers
Luke
Hi Luke, what do you mean by "powered up the yellow and black wire"?
In mine the yellow and black wire is connected at both ends, one end heads off down the back and the other end goes into the dashboard wiring harness.
So did you cut the yellow and black wire and supply +12v to one end?
If so, which end?
Or did you supply 12 volts to both ends?
:P cheers :D
Hey SK, it's been a while since I did mine, but I think the yellow and black wire went to the deck.
I definately know that it's part of the antenna harness that comes to the deck.
Yep mine ran to the deck, there was no confusion, I didn't need to cut it. Did you have the stock head unit in there when you got it SK? If not, someone may have already fiddled with it...
Cheers
Luke
P.S. does one end of that wire run into a plug like this?
(Photo credit - Alex)
And I don't think (can't be sure) that it was a thick wire from memory...
Edited by munchdesign
Cheers
Luke
It had the standard deck in it. The yellow and black wire definitely did not go to the deck. Mine and Burns are exactly the same, check back a couple of pages and you will see his post.
:P cheers :D
:P cheers :D
OK, yep, see that now, bloody strange... Mine has the AV/Navi unit in it but all that meant was that there was an extra short loom added in after the standard plug that split the wires up as required (CD player and radio/audio controls were two separate units) once I worked that out, all the wires lined up with the "How to".
Sorry I can't help any more...
Cheers
Luke
  • 2 months later...
Hey All.
Just a tip if you want a quick and easy stereo install (at least on a S1 Stag but seems like the wires are the same for S2 as well).
Buy an Aerpro loom adaptor kit from JB HiFi or similar for $14 and all the wires match straight up. Just cut off the small brown/black connectors, solder the aftermarket stereo loom in to the aerpro one by matching the colours, then plug the factory plugs into the white aerpro sockets and its all done ... couldn't be easier !! Don't forget to get the Antenna adaptor too :wave:
The one to get is for NISSAN 200SX, 240SX and Maxima, Part Number APP0120. The only lead that doesn't match is the black earth, but you can earth the aftermarket radio straight on to metal anyway. I double checked all the wires were the right ones, so its all good >_<
http://www.aerpro.com.au/list.php?pcode=AP...amp;cat_sno=160
Also, to get a 1 DIN plastic pocket to fill the hole left by the double DIN factory system. the genuine NISSAN Patrol pocket fits perfect. Part #NI-68475-35F00. $30 and looks just like a bought one :laughing-smiley-014:
Edited by exitSTAGEAright
Hey All.
Buy the Aeropro loom adaptor kit from JB HiFi or similar for $14 and all the wires match straight up. Just solder the aftermarket stereo loom in to the aeropro one by matching the colours, then plug the factory plugs into the aeropro one's sockets and its all done ... couldn't be easier !! Don't forget to get the Antenna adaptor too :(
The one to get is for NISSAN 200SX, 240SX and Maxima. I meant to keep the packet for the part number but forgot, sorry! The only lead that doesn't match is the black earth, but you can earth the aftermarket radio straight on to metal anyway. I double checked all the wires were the right ones, so its all good :O
Jeez, that would make it heaps easier! I bought the Aeropro antenna adaptor from JB, but if I'd known the loom adaptor was a straight fit too, I would have gotten one of those too. Oh well...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
